Hope this helps
-Brett
I found a new Robbins no-zipper top for $449, I might get that and install it myself. It includes a pre-installed rain rail so an idiot like me could probably manage.
Actually I'm relatively handy so I might go that route.
For $300 plus all that work, and then to end up with a plastic window, isn't worth it. I had thought it would be more like $150, but I guess not.
-juice
The NA is lighter, but the NB has the torquier engines. I you liked your '99 get another one.
-juice
Thanks again,
Mike
But not the $$$ for a full replacement top.
So I might buy the whole top and put it on myself.
thel: you did this recently, right? Where'd you buy, and what instructions did you use?
Just got a rivet gun so I'm getting motivated to do this...
-juice
As for instructions, I used the ones in the Miata.net garage. If I were to do it again, I'd use the method detailed in Keith Tanner's Projects book. He recommends removing the frame from the car and putting hte top on the frame before mounting the frame back into the car. While more time consuming, I think it would be easier and far less aggravating to do a good job doing it this way.
I would also recommend talking to a local upholsterer that has experience replacing Miata tops (most probably do several per year) and getting a few tips. It's always wise to heed the voice of experience.
Finally, invest in a good pop riveter (if you haven't already) and be sure to get a top with the rain rail already installed. Do NOT attempt to reuse the old one it will leak and it is a nnnoying to try to use the old one. Trust me on this one, if you heed nothing else I say.
Good luck!
What do you think of the new no-zipper top? It requires the addition of a couple of straps to fold the top down like the 99+ models do.
I like the idea of one less step, no zipping/unzipping.
-juice
Someone pointed out that they liked the zippered tips b/c they can fold down the rear window for extra ventilation while leaving the top up. I'm not sure how often I'd actually do that, but it might be kind of cool to be able to do sometimes...I guess.
Off to order it...
-juice
Went up to the Mazda web site and saw the 2006 Miata and fell in love all over again!!
Called a local dealer to find out when the new 2006 Miata would be on their floor. I was told around the end of August time frame. I also asked when they thought that Mazdaspeed version of the 2006 would be available. I was told that there was a good possibility that Mazda would not be making a SPEED version.
Somehow I find this hard to believe and was wondering if anybody could shed some light on what they thought would happen with the SPEED version for 2006.
Was also told that I more than likely would not be able to tell much difference between the SPEED version and the LS 2006.
Opinions, greatly appreciated.
But yeah, the new 2.0l engine makes nearly the power that the current turbo makes. Imagine what the next MazdaSpeed model could do...maybe with a tuned 2.3l?
-juice
My guess is that's where people had the most difficulty, and that created unhappy customers.
So now that vendor only sells tops with the rain rail preinstalled. I figured since I was doing it myself, to make it do-able, I'd get one.
-juice
I like the idea, saves me work but it's still affordable. $449 for a no-zipper top, complete, with glass and the rain rail is included.
Did you know the glass window alone is $359? With no rain rail! Ridiculous!
-juice
-juice
The size is pretty standard, Double-DIN. I had heard that a 6CD changer from a Tribute would fit right in, so maybe the Escape's stereo would as well. I didn't know the Explorer's would.
Did the harness just plug right in? No adaptors required?
I have my OE stereo but the CD skips and one of the lights inside the unit blew out, so I really ought to change it out.
-juice
With the seat all the way back, I could not fully depress the clutch pedal. With my foot on the dead pedal my knees still had a slight bend, however.
I'm 6' even with a 30" inseam, so you're still going to be a borderline case. Fit, you will, but I'm not sure about comfort on longer drives because you couldn't stretch out.
-juice
I'd say it took about 3-4 hours to remove the old top, and maybe 4-5 hours to put the new one on. I'd never done it before and a lot of that time was setting up, getting tools, getting a computer for extra tips on installation, etc.
I'm beat! I'm sure I'll be very sore tomorrow. That darn B-pillar bracket is nearly impossible and requires a contorsionist to remove and replace!
But she looks good, that's for sure.
To be honest I'm not sure I'd do that again. Even though I know much more now. If you can find a shop to do the labor for $200-300, my advice would be to pay them, it's worth it IMO.
Gotta let that new vinyl stretch out a bit, but otherwise it's nice to have her back to ship shape.
-juice
Now it's better, but can you adjust that cable to loosen it up a little more?
-juice
As for constructive recommendations, I'd advise you to leave your latches on the "easiest" setting possible for at least a few days and leave the top up for about a week. After that see how the vinyl has stretched. It was about a month before I readjusted the latches on mine to pull the topp tighter to the windshield. The tighter you adjust those latches, the more it will stretch out your vinyl, but it will also be harder to close the top for awhile.
About a year after installing my top, I have the latches back to the "normal" setting and I leave the top down for a couple of days at a time without too much trouble putting it back up again. That said, it still seems much tighter than the top on my 02 ever was...
-juice
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Either way, it took me a couple of hours and some spray adhesive but it was pretty easy and it looks great.
1/4 size will actually shrink the file to about 1/16th the size since it's 2 dimensional (4x4).
-juice
The prices below are MSRP before destination.....(add $560 destination charge for continental US.)
Club spec (very limited) $20,435
mx-5 $21,435
Touring $22,435
Sport $22,935
Grand Touring $24,435
3rd Generation Limited (750 units) $26,700
6 speed auto $1100
run flat tires with pressure monitors $515
suspension pkg $500
premium pkg1 $1600
prem pkg 2 $1600
PZEV emissions $ n/c
Even the base mx-5 is about $600 less than the outgoing base model. The club spec is $1600 less.
The Touring is also about $500 less than the old LS.
Solid.
-juice
A lot of folks buy these and decide they are impractical, so used they are plentiful and cheap.
-juice
All Miatas, even the Club Spec, now come with ABS, Side Airbags, etc. Previously, you had to option up an LS to even have the choice of ABS, and even then they were hard to find. Hopefully this reflects a paradigm shift at Mazda, who formerly made ABS a hard item to come by even on mainstream Proteges, 626s, 3s, and 6s.
At $20,995, the Club Spec has power windows, ABS, and side airbags going over a base Solstice. A comparably optioned Solstice would be $21,020 albeit with power lucks, but still lacking completely unavailable side airbags.
For $1000 more, the MX-5 model adds a/c and a leather wheel. Adding a/c to the Solstice brings it to $21,980, about $15 less than the Miata.
At $22,995, the Touring adds some trim bits, fog lights, steering wheel audio controls, cruise, and power locks/keyless entry. The Convenience package brings the Solstice in slightly less at $22,445.
Still, Mazda's really sticking it to GM. So much for the Solstice's price advantage. The Mazda gets noticably better gas mileage to boot, at 25/30 versus 20/28.
I really do want to root for Lutz's Solstice, and I like the fact that the LSD is a stand-alone option (you can only get it in a package on a 6-speed Miata). But I think if it came down to my money and my preference a couple years down the road, I'd probably pick the Miata.
Mike
Solistice's problem is weight, it's 300+ lbs heavier. That hurts is everywhere, acceleration and efficiency, handling and braking, etc.
-juice
Of course I live in south Florida and never need the heater. But . . . it would only take 20 minutes or so to connect it back up.
-juice
RS
I'd clean out the cowl and make sure none of the drains are plugged up. Does it make a difference if you have the A/C on? Whether you use the windshield washer fluid (could be a leak there)?
-juice
