Drew
Unbelievable! Rather than spending 1/2 hour of labor replacing $40 of pads, the dealer would rather prove a point (That it's a wear item not covered, regardless if pads still have 75% wear left). My real estate clients are scared to ride in the thing because the brakes are so noisy.
I've had the loaner ('01 ML320) for five days.
In summary, dealer would rather loan me a new Mercedes indefinitely, keep my car in his valuable shop space and piss the customer (and customer's clients) off than spend $150 to correct the deficiency.
This place needs help!
http://content.communities.msn.com/isapi/fetch.dll?
action=get_album&ID_Community= CLKOwnersDiscussion&ID_Topic=82
Now that ML added the sports package, the look I really disliked has changed. But, I do go offroading when I hunt. It is nothing too serious, but I need to drive up and over a farmer's levy, drive through cut corn fields, and rough dirt roads with ruts. The Disco II is as good as it gets for off roading, but I am sure it is more than I need. What are anyone's experiences in off roading with this vehicle? I also at times pull a trailer around 3000lbs. which I back down dirt, gravel and mud ramps into duck hunting marshes. Will the new off road features for 2001 better this vehicle off the pavement?
The problem w/ the Sport pkg is that it cuts ground clearance by 1" which you can compensate for with bigger tires and the ML320 wheels. But if an ML320 won't make it over the levy, the Sport pkg one w/ modified tires will not...
Seriously, 1998 has been known to have more than their share of problems than the newer ones. Most people would advice you to get at least a 99.
Jamie
I read somewhere that MB may be considering using variable valve timing again for their all new line of direct injection gasoline engines for 2005. We'll see what happens when it comes out :-)
Drew
With 88K+ miles you are taking a risk... assume this vehicle is a steal (under $20K?)... If it is in the mid to upper 20's you are making a big mistake. Look for a 1999 or newer... the new 2001's with full warranty (new interior, MCS...) will be going for $36Kish soon. If you can afford to stretch the payments out over a longer period you'd be doing yourself a favor... if the 98 has issues in the next 20K miles you may wish you spent the extra.
Good Luck - Frank
Who should I talk to if the service advisor doesn't take care of these issues? The manager of dealership? The salesman who sold the car? Does Mercedes Headquarters even care about total customer satisfaction? I am very frustrated and already thinking about dumping this car 9 months into my ownership.
chris
Ken, the Sport package does not reduce ground clearance because it only uses the ML430-sized tires, which of course are the same diameter as the ML320's. The ML55 has reduced ground clearance because of a lowered suspension. I'm pretty sure that the Sport package doesn't include this.
Drew
I thought some of the ground clearance loss was because of the ground effects side moldings w/ the sport and ML55?
If not, I'm puzzled as to why the MY2002 has less ground clearance than 2001 models...
MB might have changed the suspension for '02? Here's what I'm confused over though. The UK specs shows that the ML55 is lower than the other MLs, so I wonder if what I saw for the N.American specs was a misprint?
Drew
I'm trying to decide right now between buying a 2001 model ML320 with M1, M2, and M7 (perhaps bose/nav, not sure if its worth it) or waiting for the 2002. I can get the 2001 model at invoice or below, whereas I'd probably have to pay MSRP for the 2002 model. Difference would be 3-4k I'd imagine. Is it worth waiting? Other than auto climate control, and perhaps some slicker styling, are there any practical changes worth waiting for? If so, when would the 2002's be available?
M.
dt77
http://fullspeed.to/ml
Zetsche promises unique platforms, distinct identities
DOROTHEE OSTLE
Automotive News
TOLEDO, Ohio -- The next generation of the Jeep Grand Cherokee and Mercedes-Benz sport-utilities will share a significant number of components, said Dieter Zetsche, CEO of the Chrysler group.
But he insisted that Jeep and Mercedes-Benz won't share a platform as a whole, and that their brand identities will not be compromised.
Component and platform sharing between Mercedes-Benz and the Chrysler group is a touchy subject at DaimlerChrysler AG. Many Mercedes loyalists in Germany jealously guard the brand's reputation. But the company's financial crisis has tipped the balance toward sharing.
"We intend to maximize the benefits of combining two directions: Make best use of common components with Mercedes-Benz SUVs, and make best use of common components with our own SUV product range," Zetsche said in an interview here last week.
Zetsche ruled out complete platform sharing between Jeep and Mercedes-Benz vehicles. Instead, the next Grand Cherokee "will be a blend between an evolution of the current platform and some radical changes to accommodate components which will be common with Mercedes-Benz SUVs."
Common components
The M class and Grand Cherokee are both four-wheel drive and could, for example, share a transmission, transfer case and brakes.
In a related development, the company has said the next-generation Mercedes-Benz E class and the Chrysler group's new rear-drive sedans will share electronic architecture and significant components such as the transmission and axles. The rear-drive sedans will replace the Dodge Intrepid and the Chrysler Concorde and 300M in the 2004 model year.
Zetsche said in an interview April 20 in Auburn Hills that the Grand Cherokee, due in 2004, would be a totally new vehicle. "We are not talking about a new look and new interior; we are talking about an entirely new product. It's clearly not a major refreshment but an entirely new product."
A top Chrysler group executive said Mercedes-Benz executives acknowledge the first generation M class had problems. These problems include fit and finish imperfections, a cockpit that luxury customers criticized and minor quality glitches.
"They've dropped the arrogance they have about passenger cars and are turning to us for sport-utility help," the executive said. "They see we're the experts in SUVs."
The current Grand Cherokee was introduced in fall 1998. The Mercedes-Benz M class was introduced in May 1997. The Mercedes-Benz Gelaendewagen, or G500, debuted in 1979.
In Europe, the Grand Cherokee and M class are assembled on the same line in a factory in Graz, Austria.
No brand compromise?
Although Jeep and Mercedes will share parts, Zetsche insisted this will not compromise the brands' identities or their appeal to different customer groups.
"There will be no Jeep which is half a Mercedes, and there will be no Mercedes which is half a Jeep," he said. But he didn't define a limit on the amount of shared parts.
"But with Jeep we definitely haven't exploited all the synergy potential yet," he said. "I'm worrying more about achieving that than coming too close to Mercedes-Benz SUVs."
These issues are discussed in the Automotive Executive Council, which concluded there will be no conflicts, he said.
"We all want to develop our brands to their highest potential respectively but without jeopardizing their identities. For every specific detail, we weigh the benefits of possible synergies against the possible negative impact on the brands' identities. And we will always decide in favor of protecting the identity and integrity of each brand."
I tow a trailer with two big jet skies and other gear, over 3500lbs for hundreds of miles and over 75mph sometimes over 80 and no problems at all, sometimes I have to pull in steep and slipery boat landings and get the trailer over the hump and out, it does a lot better than my GMC pickup.
It is amazing how so many people fail to use the low range, either they forget or don't think about or do not need it, anyway is better to have and not need than need and not have.
See you all at Powertrip tomorrow.
Any advice or suggestions would be most welcome.
(You know the filter... The one MB say's to replace every 2 years)
After 24 K it was disturbing and yes replaced.
I always replaced my engine air filter on my 88 Jeep Cherokee every 5K and again MB advised me during the @ service Not to Worry.
with 4K before the B service I can guarantee it will be replaced then.
Thanks to everyone who shares and cares we enjoy our quality vehicle
Mike - Central Florida
The dealers I have spoken with are trying to push the 2001, claim MB will soon be offering good incentives.
Any confirmed 02 pricing yet? If I do order a 2002, should I settle for MSRP or has anyone done better?
proteus456 "MY2002+ Ford Explorer/Mercury Mountaineer" May 19, 2001 11:22pm
Drew
The only page that you should be bookmarking is the main Town Hall startup page, which is http://townhall.edmunds.com/cgi-bin/townhall . You will see a "message centre" link on the left hand column (just below the "login/logout" button), and you can jump to your message centre from there. There is also a
You can also "mark" any messages that you find useful and might want to refer back to in the future. Links to these marked messages will appear in your message centre as well.
Of course, you can also access the different Town Hall message board categories (i.e. SUVs, sedans, etc.) by using the dropdown list on the left side, top of the page.
I hope this helps. If you have any further questions, please feel free to ask.
Drew
Thanks for any insights.
dt77
Also, can carseats fit in the 3rd row?
