I just went there and configured an ML430 the way you spec'd it. I got a MSRP of $49,060; invoice of 45,671; and CD price of 45,771. I've actually seen ML320s priced below invoice.
Give CD a try, you never know.
Sometimes you get unlucky and get a car that is a lemon. Cut your losses, sell it, and get something else.
I can understand getting into class action suits because of a serious injury or loss of a job, or something like this. But to do this because a car has a rattle in the sunroof that the dealer can't fix? Or because it has been in the shop more often than you think a "MB quality vehicle" should be? Life is too short to be expending this much time on such things or burdening our legal system with such minutia.
- Mark
http://mbspy.bacosys.be/w163fldc.htm
They replaced mine and I hadn't had any problem since. The first time I went they said they couldn't duplicate the problem which is BS since the SA knows about it, and I had to go a 2nd time.
Don't know about installation because the skyroof comes with that deflector but that deflector will reduce the wind.
Both vehicles' gauges then sat on that 2/3's full mark for quite a while until (it seems) the actual fuel level matches the gauge.
I put 300 miles on the loaner and I just finished an 1,000 weekend trip in my ML and this seems pretty consistent.
By the time I got to 1/8 the tank seemed only slightly pessimistic, which I prefer compared to GM's optimistic 1/4 tank. (You should see the gauge drop in a Tahoe once you get to 1/4 tank.)
Just comenting on the efficiency of the diesel engine, I have a lot of acreage in my house, several lawn movers and a Ford diesel tractor, a little 20hp mover will consume over 4 gallons to move the yard, the tractor which weighs 6000lbs and is using a 7ft mover will do the same area in less than a 1/4 of the time and use less than a gallon.
I just sent the other day an E mail to VW, they are supoused to come with their extra cab pick up with that monster diesel, V10, all aluminun, twin turbo, 320hp and 550 ft/lbs 6 speed tranny, looks real good, if they come out soon I will hold trading my GMC pick up.
I was just driving down the New York Thruway and passed a brand new 2002 Buick Rendezvous driving at 70 MPH with its reverse lights on. I think that's a bigger deal than a rattle in an ML...it may be annoying, but it's not unsafe.
-Todd
I was a bit disappointed with the C240. While it is a great deal better than the previous generation C, it still lacked some feel in the steering wheel.
I have to agree that the MBs do fee a bit more thin, compared to the days of the 560SEL. I dont thing that the S and the CL have lost it asmuch though.
I was sorely disappointed with the continentals that were on the Cars. From the CL ESP demonstration to driving the CL on the test drive. They lost adhesion rather fast. My father's CL came with Michelins and were much better compared to the Contintntals. I know people are going to say that they were worn down because of people driving them so hard during the day. I got there early and they were not worn down to where they should be so slick. To show the true performance of the car I think that they should have chosen a bit higher performance tires like S03s or Michelins. But then again it would be realy expensive to run the test track and Continental was sponsoring the event.
Another thing about the tires is that during the presentation they said that all MB cars get Contis accross the line, which is simply not true.
Robert
The Vancouver event was held up at Mt. Seymour, a local ski hill and provincial park. Because it is a park, the off-road course was the highlight of the day, even though we only treaded lightly. Unfortunately because of this very same reason, there was limited space for the handling dynamics course and the drag race. On Sunday, it was also raining not to mention that later in the day it was very foggy, with visibility limited to about 3 car lengths. The drag race + dynamics courses were temporarily shut down because of the poor visibility. The integrated front and rear foglamps (front ones are activated as standard from the factory for Canadian MLs) came in very handy in the off-road course.
Since many of the participants there had not driven MLs, there were adjustment periods for them. Some longer than others. There was a lady there who ran off the handling dynamics course (she went outside the cones, albeit at very low speed, because she didn't know where to go) twice!! She also did a three point turn when a single turn would've surficed due to the ML's very tight turning radius. A few of us waiting in line found it rather hilarious ;-)
As mentioned the off-road course was by far the most enjoyable, partly because most of us would never subject our own vehicles to this. I found it interesting that it was not noticable to me when one of the wheels lifted one or two feet into the air. The only way that I knew was by the blinking 4ETS/ESP warning lamp. Participants praised the ABS and traction control saying that it was very unintrusive and barely noticable. Someone remarked that it was much less than the ABS in his Subaru. The diveplanes (lower spoiler for slightly improved downforce aerodynamics) on some of the MLs that were used did take a beating though, due to the sometimes hard landings that the participants put the vehicle through. The one on the ML430 that I drove was partly broken off. Not to worry though, these can be easily re-attached or removed for off-roading.
We had the roller ramp demonstration where the ML is driven up a special ramp simulating loss of traction in one, then two, and finally three out of the 4 wheels. We then drove down the other side (about 27 degree downwards). No problems at all with 4ETS managing the power. The frame twister test was great too, and the front and rear doors + the tailgate were all opened in succession to demonstrate the excellent torsional rigidity of the ML. Participants were invited to sit in the ML during this demo. I did and had my camcorder running at the same time. I'll hopefully have video captures sometime soon.
In the same tent where the roller ramp and frame twister demo were conducted, they also had a cut-out model of the ML. The high strength steel areas (300% stronger than regular steel) were highlighted in red and yellow.
Here are a few pictures:
I also had the priviledge and the pleasure of meeting a few Town Hall'ers at this event:
A lot more pictures here:
http://albums.photopoint.com/j/AlbumIndex?u=137587&a=1557355&f=0&sp=0
Drew
Check out this newly released CNN.com article:
http://www.cnn.com/2001/US/06/19/ford.tires/index.html
The General Grabber tires allegedly have a pretty high seperation rate. It doesn't specifically say which model of the Grabbers though, so I don't know if it's the ones that are fitted to the MLs (which were built to MB's specs). I haven't heard of any tread seperations on the MLs, but have heard of a small number (under 5) of blowouts for the Generals in the last 4 years. No one rollover or sudden swerves/los of stability though. The MLs were fine and the drivers simply pulled to the sides of the roads. However, this news does make me glad that I have the Dunlops; I would've had them swap to the Dunlops if my ML had come with the Generals anyway. FWIW, I found it interesting that all of the ML320s and ML430s that were used in the M-class adventure event had Dunlop Grandtrek tires.
according to the news, Consumer Reports have a problem with the Mitsubishi Montero in accident avoidance maneuvers:
I think I saw a very similar picture in the German auto, motor und sport magazine as much as a year back - so there may be someting about it. If I remember right, they refused to test the vehicle until some modifications were (successfully) made.
Birger
I owned several GM products, presently included a GMC pick up and nothing on that pile drove as precicely as my ML. I cringe when I hear about those reports, ... so an ML had a rattle, no good then? ha.
All I can say, with all sincerity, is that there is nothing in all of the GM stable as sophisticated and well engineered as an ML.
Those trim and fit issues are a problem of execution and lay squarely on the plant in Alabama.
When I first bougth my ML I started reading and hearing about those surveys, where they basically said the ML was not good, at the bottom of the pile, practically. I became concerned, I said to myself, I made a mistake, to use clean language. As time went I realized there was nothing wrong with the vehicle, now into my third year I had no problems, is a truck that rides like a car, in fact better than many cars, so much so that when is time to get a new SUV it will be another Mercedes.
I was responding to the inane observation made by redgoatee that he saw a Rendezvous with it's reverse lights on, thereby implying that it is an unsafe, poorly built vehicle.
As you have demonstrated, when someone makes an attack on your car, you will naturally respond to set the record straight. That's what I did.
I completely agree that Mercedes builds good cars. So does Toyota, Volvo, and Buick (GM).
Thor, that is why I came here and posted that inconsequential JD Power "tidbit."
What doesn't make sense is for a Mercedes sedan owner to come to this area and post nonsense about someone's Buick, and then use that observation to trumpet the superiority of the ML.
Redgoatee, if you are interested in discussing the pros and cons of the Buick Rendezvous in an intelligent manner, come over to the RDV forum. We'd love to hear from you.
I forget which newsletter it was in, or even if it was him! I dont have time to check here at work, I'll try when I get home.
Robert
Gregg
They don't seem to realize that when they take a high center of gravity SUV and make abrupt turns at 40mph it will tip over.
Wait until they take a Boxster and SC430 offroading. Their headlines will read
"BOXSTER STUCK ON ROCK! WE DEMAND A RECALL!"
You can see a video clip here:
BMW Car club video clips
Drew
Wally
I have 30,000 miles on my 99 320 ML Dunlop "t" rated tires and expect to replace them before next winter for safety in the snow and ice conditions here in the Rochester, NY area.
Anyone with experience with snow tires? I have yet to see any reviews from the group particularly with respect to traction vs noise vs wear tradeoffs.
Help this summer would make my fall decision easier.
By the way I am extremely pleased with the Dunlop Grandtreks. Someone did post that Dunlop is to offer a replacement model for the hard to find Grandtrek TG 35. I've seen nothing since.
The advice to keep them at a minimum of 32 psi all around is on target for proper wear and ride.
Lastly, to the post desiring a Michelin replacement, I would suggest a trial if you can find such in your area. Mich makes many SUV/truck tires and you absolutely do not want to upset ride and handling characteristics with a construction contractor's off road pick-up truck tire!
Refer to Automobile magazine, March 2001: they use an MB ML 320 as a SUV tire test vehicle.
It is rather comprehensive and reviews tires you and I may not have considered.
Reviewed tires includeed Yokohama,Goodyear, Pirelli,Michelin, and BFGoodrich.
Hope this may be of help.
Gereld
Why is it so inane for me to say that it is unsafe for a Buick Rendezvous to be moving FOWARDS at 70 MPH on the NY State Thruway with its LARGE reverse lights on?
I'm not knocking the Buick. And I'm not saying it's an unsafe vehicle. It was just an observation. I'm just saying that the problems reported on MLs are for the most part not safety issues.
I just think it's "inane" to have two bright lights right in your eyes as you're merging onto a busy highway...
-Todd
Depends on what you want. Do you have anything you realllllly want in the 2001? Some people would say the auto climate control. I'd say the curtain bags. Are these item worth $4K to you (diff in a 2001 and 2002)? Do you want a skyroof (only in 2001, and none in 2002)?
We can't give you advice until you tell us in lots more detail what you want.
Tires:
For folks that have upgraded tires, could you add a tire log at www.keysolutions.com/M-Class please? Tirerack has a nice rating system and all, but they don't categorize by car.
redgoatee:
I agree about the lights. I've seen other cars with that "feature" as well :-)
I live in Dayton, OH and I'm interested in purchasing 2001 ML320. Could you advise me the dealer name, contact name, phone number that give you that deal?
BTW did you see any ML320's on their lot?
Tran
If it had been a '72 Nova, you never would have brought it up. Clearly you were implying that the Rendezvous has a safety related problem that would never appear in a Mercedes.
The ML is a great vehicle. Well engineered, safe, luxurious, and comfortable. Clearly among the best in it's class. For over $40,000, it should be.
No, I don't think the Rendezvous is "better" than the ML. Nor do I think it's "worse". They both have pros and cons that meet different needs and fit different lifestyles.
Again, this debate does not belong here and I invite you to discuss this or any Rendezvous issue you may have at the Rendezvous forum. We'd be glad to hear from you!
P.S. As to your comment, "...problems reported on MLs are for the most part not safety issues." I submit to you -
1998 ML active seat and shoulder belts and belt anchor recall notice dated 01/2000:
"The latching mechanism on the seat belt assembly was not assembled correctly...in the event of a crash, the seat occupant may not be properly restrained, increasing the risk of personal injury."
That recall for 1998 ML's didn't come out until over 2 years after the car hit the road (no pun intended). I hope all 1998 ML owners were informed of it.
About the recall, if you read my sentence, it says "for the most part..." I'm aware of the recall, because my parents drive a 98 ML320. And from my knowledge, I don't think anyone was injured from the defect. I'm sure others in the forum know more...
Steve
Jamie
Jamie
