Visitor Agreement.
Mark is going to have my head for this :-)
Drew
Edmunds.com Townhall co-host
Vans and Aftermarket & Accessories conferences
The screen width for the table it too wide.
Can we change it. I can't read the posts every day. Help. I really enjoy this forum.
Mike
format - better functionality.
dt77
Change is good. I think.
I put gas in it only about 4-6 gallons go intothe tank. When my wife used it the other day and I got it back the light on
the gauge was lit so I filled it and it took 14.5 gallons. Is the gauge like this in others or do I have a problem?
Thanks for your input.
Dealer replaced it under warranty. Works fine now.
Dave
Regards & greetings of the Season
tracy
Since its been replaced, I've never had a problem.
BTW..My wife's 00 ML430 has never had any of those problems. Guess its just the luck of the draw.
The old Townhall was a product of years of hard work and lots of tweaking. We HAD to move from it since the software that was being used (Well Engaged) was not being supported any longer by the company. They basically had no idea how a lot of it worked and hence the Edmunds.com techs had to try to coax it onwards by themselves much of the time. There were also various underlying software quirks - that most users didn't know about - that were causing problems. We've been on this new software/format (Web Crossing) for less than 24 hours, so please bear with us while we tweak the interface and squish the bugs to make this place as good as or better than before. The team has literally be working around the clock for the past few days trying to make this all come together before the holidays.
As for the lost posts in Well Engaged, there was a warning up (for a few days) on the main Townhall page that posts made between Wednesday evening and Friday afternoon would be lost due to the data migration. However, although I'm not supposed to be able to do this, I've gone back and copied most of the posts made during that period. I'll post them (hopefully) later today as things become a little more organised.
Those of you who liked the placemarks feature (myself included), Web Crossing has a similar feature that will probably be activated later on as the more serious bugs get squished. It is at the top of the priorities list. Note that you will not be able to get back your old placemarks list though. Sorry...
Anyone experiencing login problems should do the following:
1. Disable autologin
2. Logout
3. Login again manually
We are aware of the above problem and are dealing with it. Any questions or concerns about the new software can be posted in the New software! Your questions answered... topic.
Thanks for your understanding and I hope this helps!
Drew
FYI, the lost post I mentioned was from last night.
Seems ok now, though the width of the new format seems much wider than before.
No search engine still? :-)
Go back to your dealer (or better yet, go to another dealer) for your heater problem.
Joe
Don't think you understand the difference in caliper/rotors from 1999=>2000+ modelML430/ML55. The rotors and calipers are larger so there either has to have been a modified mounting bracket or the lower strut assembly has been modified.. This was my question - I'm not looking for an "off-the-cuff" answer... All Ml430's have 17" rims from the factory.
Frank
Jamie
I listened under the truck, I feel the sound has to be coming from the exhaust somehow, with all the metal tubes and stuff , it must be contracting and perhaps touching something. Becomes more bothersome, when you hear it. My brother heard it too and make a negative remark about MB.
As far as the H3 bulbs, I will no longer venture in that neck of the woods, the current fog lamps work, not sure what make or type, but what the heck, price was right ( FREE!!!) and more than I had before. " if it isn't broken, don't fix it".
I'm making this post not to stir up a war, or to say I suppose the author's opinions. However, I thought it was interesting that James Healey still has the same opinion several months later (presumably after some folks have argued with him over it).
From a 11/3 chat transcript, documented at:
http://www.usatoday.com/community/chat/1103healey.htm
Rochester, MN: I have heard some negative comments regarding the 4Matic system on the Mercedes M Class and E Class. What are the major drawbacks of the Mercedes 4 wheel drive set up?
James Healey: It uses traction control to achieve all-wheel drive. Thus, it keeps trying to use the brakes to slow one wheel in order to transfer power to another. In extremes -- ice, slush, etc. -- where all wheels are slipping, the system tries to simply stop the vehicle instead of trying to keep it going. All-weather 'go-ability' presumably is what people want when they spend extra for four-wheel drive. You can't count on traction-control-based systems to deliver it.
Those brush guards don't fit on the ML55 and since the Sport pkg is basically the ML55 bumpers, the brush guards probably won't fit either...
William:
I guess Healey hasn't found the ESP off switch yet, eh? It'd sure help him along in his Darwinistic evolution :-)
The switch will turn off ASR (the speed reduction component so you don't break the tires loose and lose control). If you're good enough, you don't need ESP on...the pro drivers on the MB PowerTrip were power sliding the ML55 w/ ESP turned off. I'd personally like to be there when Healey turns it off while in a snowstorm...
Here is the link again if you need it:
http://store.yahoo.com/rodi/dooredmol.html
Take care - Frank
I spoke with someone at Clair on Thursday. He said that 10 minutes prior to my call he was on the phone with Mercedes and they told him that they have a target date of summer 2001 for the brush guard and side steps we are looking for.
yes ken
enjoy ...
http://fullspeed.to/ml
dt77
seems like everytime i try, it only bookmarkds the townhall page...hmm..
dt77
Thanks for the pic of the Manik brush guard mount. It does look pretty sturdy. At this point, I'm going to see what MB's Type II brush guard will look like. They have a new 2001 accessories catalog w/ what looks like the M4 brushguard (probably the reason they cancelled the M4 pkg for 2001).
The black star also looks great on your black ML.
Chris
If you can, get a 2000...
Other times I bounce back to the front page (not this forum), and I know that it didn't take my message for whatever reason.
I've been copying my messages before hitting "post my message," just in case.
Jamie
my 2001 doesn't do that. It probably just needs an adjustment. I do have a slight occasional clicking from the driver's window area. No clue what's causing it yet, but I use that window a lot (tolls). Seems to go away if I lower and raise the window, so maybe I got junk into the door.
My dealer keep telling me that it is "on the truck". Is there any way I can find out exactly where the truck is ?
Dave
MB doesn't give the dealers tracking info after it gets on the truck. They can only find out when your ML left the prep point on the way to your dealer.
Does turning off ESP shut off ASR? I remember that turning off ESP actually just highly diminishes it (to 20%?).
Not to belabor Healey, but I think that he's fine with most aspects of ESP. He did co-write that article talking up stability control. I think it's the power-cutoff (ASR) component of 4ETS that he just doesn't like. I think he'd rather fishtail back and forth (even dangerously so) instead of slowing down or stopping. Maybe the MB ASR software is a bit "conservative" for whatever his style is? It doesn't sound like he's cracked up non-ASR vehicles, so maybe the limits are aimed more at the less-experienced driver (though obviously a lot of folks wouldn't even give Healey that).
Drew
lemme try again.
chris 168, i'm not sure what to tell you. loads fine for me and no one has told me it can't load on theirs. I did have loading problems when my site was hosted on xoom (now owned by nbci.com) but I have since moved the site elsewhere. What version number do you see when you load my site ? it should say V 1.0 on the bottom. if now, maybe yer loading something outdated..not sure...
also, pics may load pretty slowly depending on your connection. they are on average 200,000 bytes each ..
here's the direct url, maybe worth a try:
http://www.stas.net/dt77
let me know. late.
dt77
something like that ? Searching for it is a pain in the A55 !
dt77
Jamie
I guess some experienced snow drivers don't mind or are justd used to slipping and sliding and trying to power their way through slick conditions, and I suppose Healey fancies himself that and wants everyone to be that way (not me, no thanks!). I laughed when I was watching the local news, showing some permanent residents of the heavy-winter, snow-bound areas near Snoqualmie Pass here. I'm pretty sure I saw one of them getting around in a Carmen Ghia (with chains)! Meanwhile, urban folks trying to get out for skiing and snowboarding seem to have their hands full, even with 4WD.
The 1999 ML's had substantial safety features added... such as ESP, BAS (brake assist), had a child safety seat sensor to deactivate passenger side air bag with proper MB child safety seat installed... So don't go 1998 but 1999+ on would be fine... Just look for low miles and MB warranty still in effect... look at the past vehicle history from dealer who serviced it...
Once you find a particular vehicle in your area let us know exactly what it is and we'll tell you if it is a good deal - in our opinion!
Good Luck - Frank
As I mentioned earlier, the TH team is working around the clock at fixing the glitches and adding features. Something equlvalent to the placemarks feature in Well Engaged has now been added, ahead of schedule. Note the "Mark" buttons at the top of each discussion topic/each message, as well as the "Message Centre" and "Subscribe" buttons near the bottom of the page, above the post box. You can access the topics you "mark" via the "Message centre" button.
Note also that the message width has been reduced so that it doesn't stretch out as far across the screen; the font has been changed from Arial to Times New Roman. The small font in the post box for those of us who use Netscape is also being taken care of as we "speak".
Hope you all will find this new message centre feature helpful!
Drew
