Visitor Agreement.
I pull sometimes my boat, a 23 footer (pretty heavy boat) on a tandem axle with no problems and no strain, a particular landing I use is very steep, I like the option of having a deep reduction, it makes the whole affair effortless.
Catastrophic failures are almost unknown in the ML, most problems have been small stuff, a rattle here or there or a switch, etc, things of that nature. If you have a warranty it should take care of a bug here and there, they are not that many and once cured (if any) the vehicle is very trouble free. This horror stories you mention are just that, stories.
Maintenace requierements are no more than any other vehicle, althoug the dealer service is expensive, you can buy your own filters and do your routine maintenance.
After 85K the vehicle is tigth as new and the steering as precise.
Also, owners manual says to baby the engine for the first 1500km. How seriously should I take that?
It is agood practice to allow new surfaces to mate to each other under the easiest possible conditions, low speeds reduces friction heat and easy acceleration reduces bearings loads.
Just curious, what passes for scorching up there in the Great North? My '02 ML320 A/C does fine here in the Louisiana bayou.
Phil in N'awlins
Anybody else experiencing this? I see no malfunction indicator lighted up. This usually means that if I take this to a dealership, they run "codes" and tell me that they see nothing wrong and that everything is checking out right. This is the annoying thing I found with cars that use this technology. Unless a code is recorded, the dealership thinks that nothing is wrong. Thanks in advance for any responses.
Also, if you notice on the temperature gauge, the "red zone" does not start until you go over 120 C.
I hope this calms some of your concerns.
I first purchased my 99 ML430 in 1999 or late 98, new, after my purchase I started to get involved in chats like this one for the only purpouse of entertaiment. I was not aware that I had a quality problem other than reading opinions and then reading a couple of surveys, by the general consensus I had bougth the worst vehicle made, if you believe the opinions of those that never had one or sat their behind in it. Going into 4 years now I only had a few squeaks and rattles (upholstery and trim related) and that is on rare occassions, never bothered with the dealer, the only problem I had was with my brakes dragging a little, after the third or fourth incident in 3 1/2 years I took it to the dealer, the repair was beyond and above of what I expected, first class.
I dont know what your mechanic is talking about unproven new technologies, if there is one thing I never heard about is engine and transmissions problems of the catastrophic type. Both of the engines have been award winners for several years now. There was an issue with the fuel pump cloging up but long ago resolved. The wast majority of the problems reported are the annoying type, a switch, a rattle, a brake squeal etc, MB is very good at resolving the issues and once properly cured they are not recurring.
I have several vehicles so I tend to use them at whim, but for the last two years or more I use my ML to tow my jet skies about 2500lbs or my boat over 5000lbs, for a long distance. On very steep ramps the low range is a plus, it pulls that heavy load with no strain. If you look underneath you will see the heavy build and the very large transmission.
The general agreement is that the problems encountered are of the execution type at the Alabama plant, the only thing that comes from Germany is the engine and drive and problems with it are again, almost unheard off.
I still have several of my older Mercedes and belong to the Mercedes Club so it pains me to see the deterioration in quality and service (the most recent CSI has Mercedes below average) that has occurred over the last 25 years. I hope the can turn it around.
The erosion in quality especially with the ML has reached scandalous proportions in the German press to the point that the new CEO admited the situation and in a press interview in Spain he said it was his personal agenda to reverse this situation and the first steps have been implemented to clamp down on suppliers and their quality to the risk of losing their contracts.
From what I understand, the '00 model had the 3rd seat access modified as well as the 3rd seat removal. Is the "early" 3rd seat access (tilting forward of the 2nd seat) and removal that bad?
The '02 (same as '00) had extremely easy access and removal. Salesman said earlier ones were a PIA.
Please comment - anyone!
Dave
'00 T&C soon to be ML320
Steve
tidester
SUVs; Aftermarket & Accessories
I just wanted to know if there are any deals going for 2002 ML320. I wanted to trade my 2000ML.Thanks for the information
Vic
angel
http://photos.yahoo.com/airbur
So far zero quality issues.
I enjoy the ride and the roominess of the vechicle.
Sure, there are little things that I would suggest for future models, which, have been discussed previously.
As far as deals on end of the year, I have heard of $1500 incentives ala 2001. When I purchased mine, I got it for $300 over invoice. I think any dealer now would sell it for $500 over, I think you can do better than that.
About the air filter have you ckecked the owners manual? if it does not say, as a rule 20 to 30k is the norm, a lot depends on the enviroment the vehicle operates, the first thing to do is to make a visual inspection.
I wanted to check out the photos of the future MB minivan you spotted - but the album your link pointed to was empty (last modification made yesterday 8/31). How come? Someone big from MB breathed down your neck??
Please post them back if you can - TIA.
Cheers,
Birger
In fact in the mbnz.org ML board there is a discussion going on rigth now about the ML 55.
http://12.103.217.166/forums/w163/list.asp
On a side issue I need to rotate the tires again. The first time they rotated front to back. This time I want them to cross rotate. I have always rotated tires on all my vehicles this way & have gotten thousand's more miles on the tires, but I've never done it on a 4 wheel drive vehicle. Is it OK to do this? Thanks for your input.
If anyone can provide a link for a review of the '03 model I would appreciate it. Thanks in advance.
tidester
Second, mileage is dependent on the driver. I've gotten 20 mpg regularly on my ML320 if I stay on the highway a fair amount and don't over accelerate.
Third, SUV owners don't care about gas mileage.
Fourth, these are very different vehicles. I debated about Tahoe when I was looking at the ML because the Tahoe rides really nice on the highway. But on street roads they are bears compared to the ML; in parking lots there is no comparison; and on country roads the ML's ride and handling make it just plain fun to drive.
If I had two kids instead of three, I might have gone for the Sequoia for the extra room. Fortunately I don't need that extra space because I love driving the ML and I've never regretted buying it (except when the dealer gave me an SLK320 loaner).
Am I in a dream world or what? Would anybody in their right mind trade a 2002 for a 98 vehicle with a bad reputatiion? What do you think? Is it worth it?
PS The '98 is the only year that I can afford and it's taken this long for it to get in my price range, so buying a newer ML is not an option for me.
I would not do it.
http://www.edmunds.com/reviews/longterm/articles/
What I had originally done was to click on "Helpful Links" which features the '02 ML320. It's possible the screen I see may be a little different from the one you see.
However, you can find the articles by going to the Longterm Road-Tests page that you referenced. Once there, type ML320 into the input box at the top right then click the search button.
Several articles will be listed including the one of interest to you and which is current.
Let me know if you still have trouble finding it.
tidester
We'll check it out!
Steve
