Visitor Agreement.
Did you get the vehicles complete service/warranty history from the dealer yet. You may want to read up on all the problems the 98's had and start making a list - quick... you only have @8k miles left prior to factory warranty expiration.
For example - you've probably been reading the posts regarding the 98's final drive ratio changes ... you may want to turn sharply to full lock and see if you get binding and a growing noise while slowly driving forward or reverse. You should probably claim as such to get a new final drive while still in warranty... at least you'll get a new drive with fresh oil... one less thing to worry about. There are many other issues but depending on the former owner they may have been resolved... that is why I asked if you have the complete dealer service/warranty history.
The key may have a dead battery or the dealer never programed it... you should get to know your dealer and this would be a good begining...don't wait for the final hour to bring it in for warranty service... depending on the local MB dealers some will actually look vehicle over for the many items that have been refined/updated and replace them... it would help to make a list though... start with fuel pump high pitch whine (intermittent)... binding groaning noise on full turn, door seals don't seem to seal well (new seals), doors don't shut firmly like an MB (there have been several latch updates for all doors and rear hatch), rear seat rattles (new frame design)...control arm bushings (front and rear for noise)...steering pump (noise)...intermitent machine gun type door lock operation (somtimes lock acutator but on mine it was the door latch itself).
There are many more but I can't think of them all but don't wait to take it to dealer UNLESS it has as full history with said items addressed.. Otherwise you will be out of luck once the warranty expires...Aftermarket warranties will not cover many of the items mentioned and there would probably be a deductible anyway ...
Use the wealth of knowlege in all of the forums and posts to get everything possible done prior to factory warranty expiration. Take it in a couple of times so you have a good record with the dealer.
Even if they don't find a problem you will have a record of making such complaint and might get some items resolved after warranty if it is well documented prior (MUST BE WRITTEN IN A REPAIR ORDER - If it is not written you will have little to fall back on).
Good luck - Frank
Jim B
dt77
Fletcher Jones Imports
Robert
anywayz, i was checking stuff this www.xenonhid.com no autoleveling ...but apparently doesn't seem to be an issue ? I think it is...
dt77
I have had the new 00 ML430 for one month and very pleased with the changes in the vehicle. The only downside is the fuel economy so far, not that the ML320 was a miser in that regard either. Well we are suppose to get a Noreaster today up here in MA, so we will see if the new vehicle handles anybetter with the esp. I wish everyone a happy and healthy New Years greeting.
There is an additional control module that has to go in and two sensors near the axles. You can get them put in as well if you do the retrofit. It's not part of the Xenon capsules.
When I write "in city", I mean in-city California-style, where even most regular surface streets have speed limits of 45-55 MPH. Only in residential neighborhoods are they less.
When cruising at nearly 80MPH, as we almost always do on the freeways here (except in traffic), I have observed the on-board computer giving me 23+MPG (average setting, not instantaneous) on a drive from Anaheim to Oceanside. While the whole tankfull was not 23MPG, I am confident that had I driven farther that I would have maintained well about 20MPG.
I am sure that if I spent lots of time in heavy stop-n-go traffic that my mileage would be much less, too. Remember, gas mileage is simply fuel used for a given distance. If you are going faster (within reason) you'll get better mileage.
http://www.chip-tuning.com/usa/main/mainmenu.html
$695 from mbworld; apparently, no soldering needed. Plug and play and unplug if needed
Increases HP to 286 and torque to 310 ..hmmm...
dt77
numbers stated are for the ML430.
for the ML320, HP is increased to 230 and torque 247
dt77
Is that even noticable? :-)
Check out next year's C32. It's a supercharged 320 engine. Not sure what the parts cost, but you might be able to retrofit it onto a 430 engine since you have the ML55's tranny.
Just got hit by another storm on Thurs (8 inches)making this the 2nd snowiest December in Mn history.
We've had over 38" so far this year, and have about 15" sitting on the ground.
My wife's 00 ML430 is great, just plows through everything. She's very very happy, and says it handles beautifully.
On the other hand, my 00 E320 RWD is a little scary. The ESP works very well, but I still don't have complete confidence in heavy snow storms, even with Michelin Alpins on all four wheels.
My next car will definitely be the E430 4matic.
Just curious,
Jamie
Also important is torque being available at low rpms. This way, you have plenty to get you moving, rather than you needing to rev the engine almost to redline before getting the maximum output.
Jim, WRT why both of your front and rear brake pads needed to be changed at the same time, it's because the ML has electronic brake distribution that shifts some of the braking effort to the rear brakes (when travelling in a straight line) so that the fronts don't have to do as much of the work. Seems like this system is doing its job well on your vehicle.
Orion Blue is one of the two new colours available for the MY2001 M-class. It's conspicuous, to say the least. I've seen a Magma Red ML55 and it really screams "Look at me!".
I use the Touchshift very frequently for upshifting. Have you noticed that the transmission will upshift (if the computer determines that it's okay) even in "D" mode if you tap the lever to the right? It's great since I can stomp on gas pedal and not have it hold the gears to higher rpms.
Drew
Host of Vans and Aftermarket & Accessories message boards
Drew: Glad the scans came through for you. I'm seriously considering the HID's and will look at Robert's site on his installation and see about ordering the connectors from where he did, Puma I think it was. If I get the connectors I'll probably order the HL assemblies some time in the spring. It's too cold to mess with now and if I wait I can have them adjusted the same time I bring it in for it's first service.
FYI, Chris told me just recently that PUMA informed him that the connectors are back ordered indefinitely. Since you seem like a guy who is pretty handy with tools, you may want to consider doing the modifications to the wiring harness plugs instead.
Drew
What do you guys do when you get the interior wet from rain? Towel it down and throw Lexol on it?
The only reason why I emtioned the X5 as being noticeable in traffic is the fact that I haven't seen an ML in (tight) downtown Ingolstadt before. I am sure it would be just as intimidating.
On the Autobahn, I had to "shoo" away an ML55 ( :-) ) in order to get by, but I am certain that between listening to his wife, talking on the cell phone and calming down the kids, he simply forgot to sink the accelerator in the carpet! While I was approaching an on-ramp on the Autobahn, an X5 accelerated, and I was astonished as to its capabilities in gaining speed. Only at 180 kph (113 mph) and over could I lose him, but it was the 4.4l V-8. Other than that, nothing interesting except a few Hummers (!) of the US forces - imagine that impression!!!
Tarik
http://www.escribe.com/automotive/european/mbmc/m10266.html
Robert
I got my 01 ML320 back yesterday from the dealership after installation of the style II grille guard (basically similar or if not the same as the sports package 2" stainless steel tubing grille guard)and chrome side steps.
Well, today after removing snow off of the truck I realized that there was a slight ding on the topside of the chrome side step (trust me I'm pissed off at myself for not checking thoroughly prior to leaving the dealership). I guess an abrupt visit to the dealer is set for the new year.
Well, enuff with the moaning and groaning about my problem... here are my questions: Do Grille Guards come with the skid plate? or is this another one of those options that dealers try to hide? I know I've read about this in the past, but is there a cure for the slanted side steps?
Thanks in advance.
Oh yeah, the ML is great in the snow, what STABILITY with the ESP.
Danny d:)
doesn't the new C have side air curtains ?
dt77
There is a chance that side curtains will be an addition for MY2002 MLs. A good chance, IMHO, since the BMW X5 will receive (optional?) head protection tubes for the rear passengers for MY2002. The side curtains are better than the tubes since they have a much greater surface area (they span from the A to C pillars) and also have the added advantage of blocking the glass from entering the cabin.
When deployed, the side airbags will extend about 4" (maybe slightly more) above the window sill. They're basically supposed to protect your thorax from the (hard) intruding door structure.
Personally, I wouldn't buy a new car without side curtains since there could be a chance of head injuries if one is T-boned at a fair amout of speed by an SUV (other than the car crash compatible M-class). The SUV's or pickup truck's (especially if there's a lift kit) high up bumper could miss the door beams and impact at chest or shoulder level. The curtains could be the difference between having a headache and death. I'll take the former, thanks! As you can see, SUVs don't have this problem since they're already high up. Of course the head curtains are still advantageous, but less crucial, IMHO, than in a car.
Yes, all of MBz's sedans and coupes in North America have front and rear side impact airbags, as well as side curtains.
The slant on the sidesteps is to allow water to flow off instead of accumulating and turning into ice.
dt77
On another unrelated note, the president of MB Canada, Ernest Lieb, said in a TV interview today that MB Canada already has 40 orders for the upcoming MB SLR and the 28 orders for the MB Maybach. Both of these cars will be priced in the $500K to $700K range. Wow!
Drew
so you were saying that the black rubber step part on the stepbar isn't perfectly level, right? It's designed to have a slight slope, right? I thought it was a bad installation on mine =P Took it back to the dealer for fixes. They claimed the screws were not tighten and chanrged me $40. I couldn't tell any different after the fixes. The rubber plates are still tilted a bit.
I was just wondering if folks could share their opinions and experience using the Touchshift feature. Do you guys find it useful. Any advice on what to do and what not to do regarding the feature. Thanks.
Did the dealership give you any grief because of the modification and/or wanting to aim the head lights?
You know what I'll ask for next :-) Pics!!! I'd like to see how it's mounted. I can't believe it has no skid plate. The M4 pkg's guard does have a skid plate.
The side steps are tilted a little to get rid of water. I'm ok w/ mine. Just wear hiking boots :-)
The new C has them. They cover a *lot* more area than the BMW and Volvo ones do. They go from A pillar to C pillar and come down almost a foot. I really wish my 2001 ML had them so I could feel good about having *all* the safety features I could possibly want ;-)
Can you believe it no skid plate, considering the dealer charged 620. installed. I will definitely investigate Tuesday of the New Year and will advise.
Any advice as to adding fog lights? seems the holes or mounting area is located on the back of the lower horizontal bar, I guess I need to fabricate some kind of bracket unless MB has something "made for" to offer. I tried to inquire but was rushed out because of the three day weekend before the New Year.
I am working on the pics.
A Happy and Prosperous New Year to ALL!!!
Danny d:)
Anybody know what changes are in store for the 2002 MLs? Be as specific as you possibly can. Is it true that the 430 is being replaced by an ML500? The 430 seems like such a great value when compared to an X5, so I'm worried that a 500 model will take it up to the X5's price level. Oh well, it could mean some grade year end deals this fall on 01 430s, that'd be fine with me :-) !! Everytime I see an ML on road I about get whiplash trying to check it out, I want my ML!
