2014 BMW 328i xDrive Gran Turismo Long-Term Road Test
Edmunds.com
The lowly hood latch hasn't changed much in decades, but our 2014 BMW 328i Gran Turismo has something that's a bit different.
It also had hood hinges that could be released to allow the hood to stand up vertically, which made DIY maintenance much easier.
Or just lowering the hood to the point where it's still ajar? Does it catch the latch like a normal car in that case, at least?
yeah, m badges on a non m car are a huge fail IMO
@zimtheinvader
happened to me a couple times that I drove off with the hood not fully latched after working on the car... You don't really notice it until you get to around 50mph (on my car)
@bimmerjay: That is interesting about the alarms and warnings but can't you see someone thinking, "pulling that lever set off all these alarms, I better pull it again to turn off the alarms"?
It is annoying to need to pull the release and then walk around the front of the car and find the latch. But it is safe. The system on this BMW seems to acknowledge that the lever can be mistakenly pulled once but not twice.
Maybe these would be mistakes made by a driver who really didn't know what they were doing. Maybe they're not hanging around the Edmunds comments section but I can assure you that there are many BMW drivers who don't know what they're doing.
To me this BMW system doesn't really offer much greater safety than having a single pull. Yes, it is safer but not that much. And does it offer that much more convenience? Really? Unless you're working with someone else and are really lazy, you're going to have to get out of the car and walk around to the front eventually anyway. You're also going to have touch the underside of the hood to open it and probably touch some other dirty bits soon thereafter. So all they're saving is the time to find that latch release under the hood. To me that savings isn't all that great and not worth the increase possibility having the hood unsecured at speed.
The question isn't whether or not carmakers should care about safety or whether hoods should require dual release. The question is whether BMW's dual release system makes sense and I don't think it does.
