The Debt-Free Car Project Chapter 2: Preventive Car Maintenance
Edmunds.com
In Part 1 of the Debt-Free Car Project, we purchased our 1996 Lexus ES 300. Now we take care of some early repairs and preventive car maintenance.
And how hard was the cabin filter replacement? In through the glove box opening?
The control arm replacement was recommended because a bushing was cracked. We will discuss those repairs in Chapter 4. Chapter 3 will be out shortly and goes over another topic.
-Ronald Montoya
1. Noise
When you are driving your vehicle and going over a bump or pothole in the road you will hearing clunking noise. Ride smooth degrades when the control arm is wearing out and you will inevitably notice a reduction in the quality of your driving experience.
2. Movement
Another obvious symptom of a failing control arm is too much wheel movement. If you place your hands on one of the wheels and push it you will feel more of a wobble. This is likened to the same symptoms of a bad CV joint or ball joint. There should be no play in the wheel beyond the acceptable level, so if you feel too much movement, have the car checked.
3. Steering Wobble
Driving at higher speeds of between 45 and 60 miles per hour will demonstrate control arm failure by exhibiting a wobbling in the steering wheel. This is similar to when the tracking and balancing is off and the steering wheel wobbles heavily when you drive. If you are sure your tracking and balancing is fine, the control arm is probably the cause.
1. Noise
2. Movement
3. Steering Wobble
1. Noise
2. Movement
3. Steering Wobble
Thanks for the suggestion. We have now added links at the bottom of every chapter.
-Ronald Montoya
So in fairness to the economically challenged who may be reading this, they need to have some reserves for repairs, insurance, maintenance, etc., they can't blow their entire wad on the purchase price.
