2016 Chevrolet Volt Expected To Expand Range, Double Powertrain Offerings
Edmunds.com
The 2016 Chevrolet Volt will be available with two separate powertrains when the plug-in hybrid goes on sale in late 2015, Edmunds has learned.
What is it? Usually May is when you can order the next year model car. Is GM holding out to December 2014 before someone can order a 2015?
The 2013/2014/2015 Volts have a 16.5KWh battery, not 16KWh.
The engine doesn't come on at 30% SOC but around 22% SOC I believe and charges to a bit above 75% SOC when you plug it in.
