2014 Volkswagen Jetta SE: Track Tested
Edmunds.com
We track test the 2014 Volkswagen Jetta SE to see what differences the new 1.8-liter four-cylinder engine and revised rear suspension have made.
I was 90% committed to buying a Mazda 6 up until a week before I read about the all new 1.8 motor. The Mazda in Touring trim would've put me a bit outside what I wanted to spend. Both VW & Mazda had the 0.9% financing, so that was a wash, but for a couple thousand less I decided to go with the VW. Never owned one before, but the new motor and the return of the fully independent suspension tipped the scale.
It has that 'solid' feel that many have remarked about with other German cars. The motor does have nice power at low RPMs. Don't need to put the hammer down to go up steep grades. It up-shifts very early in the pursuit of MPGs, but the torque is solid enough to power through that tendency. Down shifts come quickly as well if you need to pick up the pace.
I'm taking it easy on the motor this early on, but the engine is smooth & very quiet.
I read as much material as I could find about this new motor and discovered that it is a completely new 1.8. Essentially just a down-sized version of the 2.0. VW uses a very thin cast iron block with weight reduction in mind. A more advanced cooling system the reroutes coolant in an effort to lower the temperature of the incoming air.
Time will tell if it was a good decision.
Hopefully, I didn't shoot myself in the foot.
Riding on a wave of styling and marketing success that was about to crash so hard following serious reliability problems that it would ruin the goodwill of American buyers for the next decade? I'll take the new VW. That 1.8T looks like a great volume engine. If you want the successor to the 2002 1.8T, go for the more powerful GLI.
Not sure what point you are trying to make here, but the 2.5 I5 never has been paired with a DSG, always the traditional auto.
______________
A turbo stinks at high altitude....
Right now you can get the same 2014 VW Jetta 1.8T SE with auto for $19.9K at carsdirect.....26/36 MPG
