2014 Cadillac CTS Vsport and 2014 Cadillac XTS Vsport: Dyno Tested
edited September 2014 in Cadillac
image2014 Cadillac CTS Vsport and 2014 Cadillac XTS Vsport: Dyno Tested
Edmunds.com dyno-tests the 2014 Cadillac CTS Vsport and 2014 Cadillac XTS Vsport.
  • noburgersnoburgers Member Posts: 500
    great blog! easy to understand the differences, etc. outstanding power (can't wait for the new -V tests when it comes out). Too bad CA has only 91 octane.
  • fordson1fordson1 Unconfirmed Posts: 1,512
    Very, very interesting. While from an academic standpoint you wanted to see the two applications of this engine compared with one another, I don't believe there is going to be much cross-shopping of these two cars in the marketplace, and I would rather have seen the CTS V-Sport run on a Dynojet...because there are far more Dynojet pulls performed - and available for review - on the CTS V-Sport's competitive set than there are Dynapack dyno pulls. For the comparison that you did, though, I would say that the product group doing the XTS tuning knew that they were going to run much less boost, and that they probably went with a much less robust intercooler setup. The IAT temps and knock retard info is interesting, but I would also have like to see boost levels reported for these two cars. The drivetrain loss actually looks to be not that bad - up until around 2800 rpm when they pull all the boost, or throttle, or timing, or all three - out of the XTS and it falls into that horrible hole it never climbs out of. There has to have been a better way to do that - looks like a job uncompleted to me.
  • duck87duck87 Member Posts: 649
    "the LF3 in the XTS operates with higher intake temperatures on one bank of cylinders than the other"
    You are referencing intake air charge temps after intercooling? That's interesting, I wonder if there's a flow imbalance in the intercooler coolant circuit? For sure a transverse layout doesn't help, it already causes difficulties with air intake and exhaust routing.
    Are those two lines leading into the coolant bottle coming from the intercooler circuits?
  • farvy_farvy_ Member Posts: 9
    Ahhh yes. I believe this shop is owned by "church123" from the old Inside Line days. I have missed his informative posts. Looks like he fell by the wayside along with a lot of other regular posters when IL went away.
  • subytrojan_2subytrojan_2 Member Posts: 79
    Yup. That's Shawn Church's shop. http://home.earthlink.net/~spchurch/
    I think a lot of us miss his comments.
    As far as this goes, I always appreciate Jay's analysis; I just think the music is too much and annoying. I just want to hear the car and Jay speak.
  • lions208487lions208487 Member Posts: 240
    Best article to come from Edmunds in a while, and I appreciated the analysis. This engine will do wonders in the ATS V, and I am hopeful that it will be matted to the 8 spd auto and GM's 7 spd MT that is in the Vette.
  • joefrompajoefrompa Member Posts: 64
    So a genuine question: How come my 2001 e39 m5, weighing in at nearly 4,000 pounds and with "only" 394 hp, 369 lb/ft of torque, and 4. 9 liters of N/A fury...
    How come my vehicle still pulls a ~13.0-13.3 quarter mile at 108mph - besting this 15 year newer (since the m5 launched) CTS with more HP, a bit lower weight, alot more torque, and all sorts of technology.
    That's my biggest concern with this car - it's not pulling the quarter mile I would hope to see from this level of power.
  • csubowtiecsubowtie Member Posts: 143
    Joe: My guess would be 1) the BMW was under rated. It seems BMW has a history of doing that. Better to under promise (I shouldn't say under, just promise) and over deliver than to overpromise.
    2) Gearing. I would be interested in comparing the mpg of these two cars. Buyers of an M5 in 2001 probably didn't give their buttlers bum about gas mileage. Nowadays mpg is the "#1" most important factor to consumers (despite the fact that they all rush out and buy the less fuel efficient CUV version of a car instead of the sedan/hatch).
  • church123church123 Member Posts: 0
    Hi guys, yes, despite regular communication with JK, I don't post here anymore. But since there are specific questions regarding this test, maybe I can help and then disappear into the ether again....;)
    First, easier questions. Joefrompa - your M5 puts down about 360-365 whp on my dyno, so the power differential isn't that large. Nor is the weight (less than 100 lbs). Given that the CTS Vsport is turning in similar ETs with higher traps (12.9-13.1@108-110 except Edmunds), I'd say its down to traction and gearing as the M5 wears the same size rear tires as the Vsport. And don't forget that at full throttle accel with redline shifts, the engine doesn't spend any time below 4000 rpm where much of that torque advantage is. You also have to make sure the intercoolers are cooled down or else you'll lose power.
    On the topic of temperatures, yes, we were able to log temps at the inlet, as well as at each cylinder bank after the intercoolers. On the CTS, they were pretty consistent side to side. But on the XTS we saw a larger differential (20 F). The rear bank was consistently hotter AFAICT.
    In terms of boost levels, the XTS went up to about 8 psi, dropped down to 7 psi till 4000 rpm or so, and then slowly climbed to 11-12 psi of relative boost pressure at redline. By comparison, the CTS came right up to 12 psi and held it all the way across. As JK mentioned, there was a lot more knock on the XTS and this is the primary reason for the torque hole on that car. We even tried adding a little octane to the equation and it made very little difference, but where it did help was that dip. So on 93 octane it will probably look better.
    Both cars were in full on torque control mode on the dyno. You could see on successive runs that the cars were learning the engine response on the dyno and dialing back the midrange torque to hit the torque targets. And even when we cooled things down, power didn't change much at all. So, I don't think we'll see a big difference in peak numbers on 93 octane without retuning.
    In dissecting the ECU programming, there are specific torque target tables, and the ECU is empowered to do many things to get to those levels, including throttle reduction, boost reduction and timing reduction. We saw the throttle drop close to 50% right after spoolup in some cases which is where the little drop off in torque comes from. But later runs showed less torque here as the ECU learned and was more predictive. This would be less prevalent on the road because the load on the dyno is somewhat higher especially at low rpms, causing the boost response to be more aggressive.
    The ECU is arguably the most complex spark ignition ECU that GM has ever used. Not only do we have target torque tables, but the torque models includes things like turbocharger compressor efficiency, predicted turbocharger turbine speeds, and many other variables. I can't wait to start tuning them as based upon the way ECU is limiting the output in stock form, this engine will easily pump out 500+ lbs-ft of torque and 460-480 hp with minimal mods/tuning and should come close to matching the old CTS-V acceleration wise when doing so (I own a 2010 CTS-V 6MT myself). And as JK said, what does this tell us about the next CTS-V? Can't wait.
    Wow, sorry about the wall of text. Didn't realize paragraph breaks got swallowed up.
  • bassrockerxbassrockerx Member Posts: 24
    this engine seems like it is going to be a great one but not sure how i feel about it in the camaro considering the ls4 is almost as powerfull and it is undoubtedly a less expensive engine but with 6.2 liters there is more potential to be had. if this engine is going to be offered does this mean that the new LT1 engine will be coming to the camaro as well?
  • explorerx4explorerx4 Member Posts: 21,306
    Good job selling your shop to edmunds.
  • speed12silspeed12sil Member Posts: 23
    church: Thanks for the informative post. It's a shame you don't post here anymore though. While the M5 has better trap speed, it also loses big time in terms of mpg. I'd take the CTS Vsport over the M5 if driving long distance is my main use for the vehicle. That and the crash structure in the '14 CTS is so much better than the M5...
  • stovt001_stovt001_ Member Posts: 799
    Thanks for the follow up Church. Your information made already one of the best articles on this site even better. Very informative.
  • socal_ericsocal_eric Member Posts: 189
    To be taken with a grain of salt since you shouldn't believe all things on the internet without good, verifiable references (of which I can't give), but from what I've "heard" the internal target goals for the team working on the next gen CTS-V is 700-horsepower, lower 11-second quarter-mile, and if I recall correctly, something like a 400-500 pound weight reduction over the previous CTS-V. GM is also moving to a new in-vehicle controller and communication architecture that is supposed to integrate all the major controllers like body, powertrain and ABS into one module for weight and cost savings. Due to the next generation CTS coupe being developed and based around this architecture from the start, that body style is supposed to get the full –V trim a year or two prior to the CTS-V sedan since the powertrain controller and in-vehicle communication architecture will need extensive updating (read: mid-cycle refresh) due the sedan development starting before the coupe and being based on an older controller and CAN-bus architecture. There new Vsport models are definitely impressive (assuming the GM updates addressed the stretching timing chain issue for the turbocharged version of the high-feature V6) but they aren't resting on their laurels with these cars.
  • jeffinohjeffinoh Member Posts: 156
    So, I couldn't help noticing the pale vanilla color interior of the otherwise very butch CTS. Also the Halloween orange and black interior of the XTS which is kinda garish against the steel blue paint. Are Caddy's interior designers colorblind? XTS also offers a nauseating pale gray with brown(???) combo. What gives? Trying too hard to be unique.
