2014 Chevrolet Corvette Stingray Z51 Suspension Walkaround
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
The 2014 Chevrolet Corvette Stingray Z51 possesses amazing coordination and generates high limits. We look underneath to see where it comes from.
Personally, I don't see the difference between the side to side crosstalk of the leaf springs and an antiroll bar for tuning purposes, or for any purpose. Anti-roll bars already couple the left and right wheels just as much, and more - that is their function.
I'm yet to hear convincing negatives on this suspension layout. And given how Vettes handle on track versus their rivals, empirically they don't seem to be giving anything up either.
Dan and Josh, I think these articles about the c7 made me a fan of you site. Much higher caliber analysis than the rags! Thanks!
Would that more topics were covered in this way.
With thanks and congratulations to those involved
Nick Maris
For those that are new/have limited experience with the modern Corvette platform, you may find it interesting that many of the parts, although the part numbers have changed, are quite interchangeable between the C5/6/and 7 marques. Again, the C7 is the most refined and ready capable version, but it's still built on the C5 platform theme, and thus it really isn't as "new" as many may think. All that says is just how forward thinking and future proof the C5 platform really was when it came out..
In fact, if you Photoshopped the color of the chassis you would be hard pressed to tell any difference between the C5/6//and C7 because they're virtually the same chassis; and that's a good thing. The move from the steel hydroformed rails to aluminum ones (much of the rest of the C5/6 were aluminum as well) was done to lower weight due to increases the other refinements and increased engine displacement.
Since steel IS stronger/stiffer than aluminum, GM used thicker center tunnel plates in the C6/C7. However, upon deeper scrutiny the GM Marketing guys/gals were exposed about saying the C6 was stiffer, when that actually wasn't the case if you swapped the stiffer center tunnel plate out for a C5 thinner version (yes they bolt right in place between the two, lol). So GM put in the extra rib stiffeners on the C7 to get the all aluminum chassis back towards what the C5 would be if you put on the C6's thicker tunnel plate (which again, bolts right on).
However, this article superbly highlights the Corvette in its most refined form, no matter how much it is based upon its grandfather the C5, and this should be GREATLY celebrated! In fact, the C7 and the C5 are my all time favorite sports cars and Corvette marques.
Thank you for such an outstanding article; and for introducing more people to our sports car.
