2014 SLP Panther Camaro Long-Term Road Test
  • mboilymboily Member Posts: 15
    Maybe I need bigger shoes or more practice with this setup?
    Yes you do.
    The trick is to heel Sole the Brake while toeing the tip of Gas pedal.
    Since the bottom Gas pedal sits lower than the Brakes, use the Tip of the Gas pedal which is almost equal to the brakes.
    So it's basically the opposite of a standard heal-toe procedure.
    It took me a little while to master it but it works perfect now
  • hank39hank39 Member Posts: 144
    Those pedals look kinda cheap for this car. Beefier/racier pedals would seem more appropriate.
  • fordson1fordson1 Unconfirmed Posts: 1,512
    "Or better yet, maybe SLP will make pedals someday." Be careful what you wish for - at least none of these Chevy pedals has fallen off onto the floor mat...yet.
  • diigiidiigii Member Posts: 156
    For comparison, the 2013 Scion FR-S long term tester had better pedals. And that car was factorys-spec.
  • desmoliciousdesmolicious Member Posts: 671
    Just don't wear heels when driving a Camaro.
  • tlangnesstlangness Member Posts: 123
    Correct @diigii, the Focus ST, FR-S and Corvette all have better setups. And 2/3 of those are much less expensive cars.
