2014 SLP Panther Camaro Long-Term Road Test
image2014 SLP Panther Camaro Long-Term Road Test
Edmunds conducts a long-term test of a 2014 SLP Panther Camaro and experiences an issue with its serpentine drive belt leading to a roadside repair.
  • kirkhilles_kirkhilles_ Member Posts: 151
    Is it wrong that as I was reading this article, I was pretty sure that the actions taken were a guy and not a girl?
  • hank39hank39 Member Posts: 144
    Crisis averted. Glad things were worse than they could've been. And kudos to being at the right place and having good peeps help you out in a pinch!
  • diigiidiigii Member Posts: 156
    Edmunds' card to the rescue. Not a lot of owners will have the luxury of just calling their mechanic and they'll be right there in a few minutes.
  • quadricyclequadricycle Member Posts: 827
    Almost every writer has gushed about the wonderful job SLP has done, but honestly, the center console is coming apart where SLP installed their gauges and now you've encountered some reliability problems. Yup, SLP is by no means like all of those other tuners who have fitment and reliability issues...
  • jaguar36jaguar36 Member Posts: 15
    Wait, you broke down next to an auto parts store, near a 'friends' shop and the nut was still on the pulley? You sir need to buy some lottery tickets.
  • stovt001_stovt001_ Member Posts: 799
    @diigii: I have built up a good relationship with my mechanic and while he hasn't driven 4 miles to do a roadside repair for me (that's never come up) he has gone the extra mile to get things done. Years of loyalty and referring him to friends will do tha
  • noburgersnoburgers Member Posts: 500
    now, who do you submit the bill to in order to get reimbursed for the belt? GM? Will they accept that the work was not done by a repair facility? Maybe the cost of the belt is not worth your trouble.
  • fordson1fordson1 Unconfirmed Posts: 1,512
    quadricycle, as usual I agree with you completely - seat adjuster lever came off, probably because it was removed to install the different seat skins SLP puts on; the console is loose, probably because it was removed to install the SLP short-shifter, and the alternator pulley was loose, probably because the whole serp belt arrangement was changed to accommodate the supercharger SLP adds. If this were my car, I would get a comprehensive list of everything SLP does to the car, and I would spend a day in the garage making sure everything that had to be removed to change it from an SS to a Panther was secured correctly, because whoever at SLP did the conversion on this particular car was a hack. And I would be backcharging SLP for the new belt and my labor to get the car back on the road after this particular episode. I'm glad this car has the full bumper-to-bumper warranty...looks like it's going to need it. The two cars I own right now were both modded by me, one to the tune of about a thousand bucks and the other to the tune of about three thousand bucks...and neither one has ever had a mod-related failure and I have never been refused warranty coverage on either car due to my mods. I would rather have a modded car with some of the warranty voided but the work done correctly than this SLP Panther, the way it's looking from here.
  • desmoliciousdesmolicious Member Posts: 671
    And this is why the Camaro ZL1 is a much better deal than this tuner car. Still insane 550+ supercharged hp, but built by the factory.
    Think about how much worse SLP cars are that are delivered to regular customers, not an internet publication that is writing about it.
  • camrydriver69camrydriver69 Member Posts: 54
    I wish unionbuster and nukedetroid were here to comment!
    Another reason why old school gauges are becoming obsolete. The Camaro has a full set of gauges but it was the warning chime and message in the information center that got the drivers attention. People who hate "dummy gauges" that don't give real time info wouldn't know they have a problem until it is too late. Sure, if you paid attention you would notice the gauge moving from the normal center position. But most people don't usually scan gauges. The ability for computers to predict a failure before it occurs is pretty cool. The computer knows that it has all of the cooling systems on (the fans were probably on high speed) but the temperature is continuing to rise. It determines that overheating is now inevitable so it sounds an overheat warning BEFORE it happens to protect the engine and give you time to find a safe place to stop. GM's ECUs seem to have some artificial intelligence. Good job. The computers, sensors and their abilities are mind blowing. Last summer while I was washing my girl's Hyundai Sonata I placed the large towel I was using over the grill while it was running to go move the hose pipe. After a few seconds I noticed the cooling fan switch to high speed. When I moved the towel the fan slowed to a lower speed. Put the towel back and the fan switched back to high speed. I can only assume there is a sensor that tells the computer how much air is flowing through the radiator/condenser even when the vehicle is not moving. I thought it used vehicle speed for this function.
    @fordson1: Indeed, one could make a pretty good habit out of finding out known reliability problems and regularly checking them for wear, clearance, and proper torque. Out of curiosity, I'd be interested in knowing wether you chose the ST or GTI to pour t
  • hybrishybris Member Posts: 365
    I would like to say that this is how posts should be done. You have a problem, you identify a problem, then you fix the problem. It would have been disappointing if you guys just had the belt break and you left us guessing for a few weeks as whether or not you guys toasted the engine or something like before showing your simple repair job. *hint**hint*
  • duck87duck87 Member Posts: 649
    @hybris: I guess this is what you get from the engineering editor!
    It's a 2003 SVT Focus, not an ST. Its weak spot was not a lot of power or torque, so it got a high-flow intake, high-flow cat, larger throttle body, 93-octane reflash and lighter wheels. Cosworth/SVT had already taken the engine from 130 hp to 170, so the mods I did added only 10 whp and 13 wtq. The GTI is boosted, so all it got was an APR reflash and an intake...but those added 35 whp and 55 wtq. It will get a $300 Golf R intercooler this spring, because the higher boost can overwhelm the stock one under extreme summer conditions. The other thing I would be looking at with this SLP Panther, come to think of it, would be if the stock tensioner and idler were swapped for better units as part of the SC install - if they were, was it done right, and if not, are the stock ones up to the additional duty. Also, is there anything in the modified belt path that looks likely to increase the belt-throwing risk - what other than the alternator got moved (especially the tensioner and idler...)? These just as a precaution...it looks like jkav found the immediate problem and remedied it.
  • zimtheinvaderzimtheinvader Member Posts: 580
    "Upon reaching a halt, the engine ran roughly for a second before quitting." --- I'm curious, is there some sort of safety system that shut the engine down? The followup comments about it not spewing coolant and running fine with the new belt due indicate it didn't end up with the fate of most cars I've known where the engine stopped due to overheating. But it does make it odd that it stopped on its own.
    " I attempted to restart it (idling allows the coolant to keep circulating...assuming there's still coolant to circulate)" --- I've always heard the idling recommendation too, although it might be best to check for what is causing the overheating first. I've had a belt snap on me before but I was fortunate that the car had a AMP gauge rather than a volt gauge so I could instantly see that all charging was also gone as the temperature climbed which was a quick indication there was no belt driving the water pump and alternator. Duct tape twisted together and wrapped around the crank and water pump pulley managed to get me the short distance to a parts store (and being an old car I always kept some tools in it)
    Oh, I must have just read "Focus" somewhere and assumed that it was an ST. Regardless, I appreciate the information, as I think that there will probably be a hot hatch in my future (or a Tacoma, go figure). As for the SLP Camaro, I'd definitely scour forums before buying to see what I could dig up. Might be hard to find with the small sample size though.
    @stovt001: I agree with you about building a relationship with your mechanic and referring friends to him. I have done that too. But what I was trying to convey is that not all drivers, despite their good rapport with their mechanic, will not have the l
    @zimtheinvader: More likely, it hit the "overheat warning" threshold and actually shut down before the engine actually spewed coolant (can go up to 245 deg F without too much issue for most modern engines). If the car actually DID spill coolant
  • kiiwiikiiwii Member Posts: 318
    typical GM crap built by morons
