2013 Dodge Dart SXT Rallye Long-Term Road Test
edited September 2014 in Dodge
image2013 Dodge Dart SXT Rallye Long-Term Road Test
Edmunds long-term update of the 2013 Dodge Dart SXT Rallye includes discussion of the Dart's short gearing.
  • yellowbalyellowbal Member Posts: 234
    That isn't bad. My Civic Si is at 3,000RPM @60mph.
    Let's not forget the trade-off of physics. Small displacement without forced induction = not much torque. Probably an okay trade off for not having to drop two or three gears to make a pass.
  • quadricyclequadricycle Member Posts: 827
    @reminder: They have the 1.4L turbo. But yes, I think most small engine cars have this characteristic. Its actually not that 2,600 is so bad at 70 (could be ALOT worse), it just needs some more sound insulation.
  • agentorangeagentorange Member Posts: 893
    Josh, you're kidding, right? 1.4 turbo in a 3000lb+ car and you are surprised it needs 2600 rpm for 70? Really?
    My tiptronic equipped '04 Jetta 1.8 Turbo is turning 3k rpm's at that speed.
  • kirkhilles_kirkhilles_ Member Posts: 151
    No, what's disturbing is when you're in my 2000 Miata and cranking out 4,200 RPM at 80 mph (70 mph speed limit) with a pretty loud factory exhaust. For the first month or two, I kept trying to Up Shift it beyond its 5 speeds.
  • fordson1fordson1 Unconfirmed Posts: 1,512
    I find this complaint mysterious - short gearing, you say...compared to what? Spend some time with the Google and tell me how many cars in this class are below say 2500 rpm at that road speed. Your 2010 GTI and your Turbo Beetle were turning around 2700 at that speed, but nobody ever complained about it because that is a very quiet, refined engine, and the one in the Dart is not. The issue is not short gearing, it's this loud, unrefined engine. And that is particularly unforgivable with a turbo engine, because typically putting a compressor wheel in the exhaust tract is a significant help in making those engines quieter - it's very common for reviewers to complain that turbo engines don't have a sporting-enough exhaust note.
  • huisjhuisj Member Posts: 1
    A manual Fit is at about 3500 at 70. Big whoop. About the only small car I've seen that's lower than the Dart is a Cruze Eco.
  • cynic783cynic783 Member Posts: 30
    ^^^reminder the long term car that Josh is reviewing -is- the turbo lol you fail
  • bgsntthbgsntth Member Posts: 92
    Agree with the comments - not so surprising in a small, amped-up four cylinder. Now, 2950RPMs @ 70 in my Cayenne GTS Manual transmission with a 4.8l was odd, but the sound - glorious.
    Small forced-fed engines have found a niche in the current market, but are still no replacement for cubic inches when it comes to low rpm torque. ^^^cynic783 you fail. LOL
    LOW rpm? Most 2.0L turbo engines are making more torque at 1800 rpm than a 4.0L NA engine is.
    Other than a slight lag off idle, my Jetta pulls much stronger than the NA 2.5L in 2007 Forester and the 3.4L V8 in my '96 Taurus SHO (the engine looked fantastic and sounded glorious at 7k RPM's, but was one of the most gutless I have experienced in the 20+ cars I have owned).
  • greenponygreenpony Member Posts: 531
    A V8 Challenger this is not.
  • jlh3jlh3 Member Posts: 14
    My infiniti M35 used to rev at 2800 at 70 MPH It was a 5 speed auto
  • duck87duck87 Member Posts: 649
    Yeah, the issue is that this engine has a drone because it's not very muffled compared to the other engines available. But 2600 rpms itself isn't very unusual; most mid 2000s Hondas seemed to churn at 3.5k rpm on the freeway....
  • barich1barich1 Member Posts: 143
    "A manual Fit is at about 3500 at 70. Big whoop. About the only small car I've seen that's lower than the Dart is a Cruze Eco."
    The Skyactiv Mazda3 is running at 2100 RPM at 70 MPH. My previous generation 3 with the 2.3 was geared lower than the Dart, but the engine was pretty much inaudible on the highway. Of course, the higher than average road noise could have been a big part of the reason.
  • cx7lovercx7lover Member Posts: 90
    The gearing for the dart is short though. It needs 2 shifts well before it reaches 60
