2014 Ford Fiesta ST Full Test
Edmunds.com
On paper Ford's Fiesta ST is the best sporty subcompact you can buy. We find out if it lives up to the hype in our latest road test.
i would presume so. how about a $500 upgrade to no name sport seats more suited to this car? it doesn't need recaros...
Speaking of the electronics, yes they use the braking system and if you track the car may need upgraded (probably pads and fluid at a minimum), but electronics are being used on quite a few cars these days to include rear and all-wheel drive for torque transfer and you're going to see it more and more. It allows the manufacturer to tune the chassis as a whole and get it to do things that would otherwise be difficult… like making a nose heavy front driver easy to rotate and control on the street. ---------------
A mechanical limited slip in the Fiesta and Focus ST would help put power down better without increasing thermal load on the brakes as much, but if you disabled the electronics and some of algorithms such as the active torque vectoring and curve control (understeer mitigation) it would quite dramatically change the character of the car (you can test this for yourself on the ST by disconnecting an ABS wheel speed sensor to disable it while leaving electronic brake force distribution active).
ST sounds a bit too hardcore for me.
How about a GT version with a 1.5 and a 6 speed?
I'd agree that it would be nice for more cars to have them, especially high power front drivers, but from the automaker's standpoint the investment and uptake rate unfortunately aren't high enough to justify it in most cases (especially in this end of the segment although luxury cars like higher end BMWs are turning to electronics solutions instead of mechanical as well). At least with time the ABS, braking, electronics and tuning abilities should improve like all technologies but could still complement a mechanical solution for the best of both worlds.
Also, I saw the comment on Mustang GT Track Pack vs BOSS and I can tell everyone, the differences are IMMENSE overall This isn't the place to debate it, but please, just look them up and study for a few minutes. They're very, very different overall.
