2013 Ford Focus ST Long-Term Road Test
Edmunds.com
The keyless entry system on the 2013 Ford Focus ST is especially smart, allowing you to open both the front and rear doors with the key still in your pocket.
@ huybui,
This is not a fancy feature anymore, considering it is 2013. It was somewhat fancy back in 2008. Maybe 2009. Even then it was an option on several inexpensive brands.
Does the Focus have the invisible numerical touchpad in the b-pillar area of the front door? That's a great feature too, especially if you want to hide your key in the car while you run on the local trails. Just lock the door, then use your personal code to unlock them when you get back.
When I owned my Chevy, I always got a bit envious at my Ford buddy because he didn't have to figure out where to put his keys while we worked out, or worry about losing them from a pocket (military PT gear doesn't have the best room for carrying things with you).
