Fuel-Sipper Smackdown 4: Which Car Gets the Best Fuel Economy?
Edmunds.com
Edmunds.com tests the Chevrolet Volt, Hyundai Elantra, Kia Optima Hybrid, Fiat 500 and Volkswagen Jetta TDI to see which gets the best fuel economy in the city and on the highway.
Maybe someday you should do a fuel-sipper based on something normal, like daily comutes. Telling us about trips through death valley to Vegas, is about day tripping performance. I'd think the fuel sipper test would be a week of commuting, maybe measured over 2-3 different commutes (downtown, suburbs, freeway). Even here your "city loop", was 180miles in a day. What is that supposed to represent, a taxi driver?
The Volt is an electric car with a gas back-up auxiliary power generator.
Drive electric. Live free!
The previous smack down has the Prius average at 47 something mpg.
Also, where is the 2012 Camry hybrid, Prius V, and the new Insight.
I pressume that the Volt is fully charged before the start of the day, therefore, there should be a separate number of actual mpg which is the total distance traveled of each day minus 40 miles to represent the real fuel consumption of the Volt without the help of the grid electricity.
With or with out grid electrity the Volt is annihilated by the Prius on this kind of test.
While I understand the point of this smackdown is to test newer cars with a claimed 40 mpg, the fact of the matter is that there isn't anything new that seriously challenges the tried and true champ.
Day 1 country road 425.5 miles
Edmunds = 36.1 mpg
Gas only mode = 32.7 mpg
Day 2 city driving 179,1 miles
Edmunds = 44.8 mpg
Gas only mode = 34.8 mpg
Day 3 Highway driving 230 miles
Edmunds = 45.2 mpg
Gas only mode = 37.3 mpg
Overall 834.6 miles
Edmunds = 41 mpg
Gas only mode = 35.1
Below is my take on the the Volt in gas only mode.
As you can see, the Volt on the country roads (gas only mode) is as good as any other fuel efficient mid size sedans at 32.7 mpg.
On city driving (gas only mode), at 34.8 mpg the volt is roughly as good as any other mid size hybrid cars (hybrid fusion, camry, sonata, altima).
On highway driving (gas only mode) at 35.1 mpg is again about the same as most mid sized hybrid cars mentioned above.
Overall gas only mode of 35.1 mpg is also the same as most mid size hybrid if you double check with actual drivers' input at fueleconomy.gov website.
I believe that the weight of the volt being in the midsize category due to the heavy battery produced gas-only-mpg results that is consistent with that of mid size hybrid sedans.
Wait a minute! What about the prius? Well, the prius beats the Volt (in gas-only-mode) the same way it beats the other mid size hybrid sedans in fuel consumption.
The Volt has 40 miles electric range. After that, the mileage is better than all mid size sedans and as good as any mid size hybid sedans (hybrid versions of Camry, fusion, Sonata, Altima, Optima). However, after 40 miles, the gas only mileage is not as good as the Prius. But the Prius does not have the comfort and performance of a mid size sedan either.
1. Most people will primarily be concerned with mileage and driveability while commuting, in rush hour traffic, on a combination of freeway and surface streets, something they didn't even give lip service to. Do we spend most of our time driving to Vegas, through Death Valley, or going to/from work?
2. Rarely in the article is the purchase price of the vehicle even mentioned! This is a HUGE factor in chosing a car, especially when comparing a $40,000 car to $16,000 cars. One would assume that the consumer is especially concerned with these factors, if they are reading this article.
the only downside i have experienced in 8 years of ownership is the maintenance. whereas i can get my wife's honda, and my chevrolet truck serviced for under 35 dollars, my tdi's 5000 mile intervals cost me nearly 100 (as high as 130 if i use the dealer network). synthetic oil and fuel filter servicing the main culprits.
the addage, a good thing never lasts, apparently applies here.
In the real 'real world' most people drive ~40 miles back and forth to work. And in such circumstances, you will hardly burn any gas at all in the GM Volt.
When you consider the Volt's initial cost and the fact that it requires premium grade fuel, cost of ownership over three to five years destroys any advantage it may have over it's competitors.
The real cost of driving a Volt excluding any tax incentives from Government Motors is prohibitive for the average family.
Just my opinion,
Don
> no diesel-powered cars on sale
Do you not even check your own links? That test included a Jetta TDI. Which is a diesel....
More *quality* reporting from one of the biggest hacks at Edmunds.
