Good and Bad News Emerges From CAFE's Fine Print
Edmunds.com
Proposed new 2017-'25 CAFE standards raise issues of safety and choice, and will make cars more expensive. But the fuel economy rules could save car buyers money in the long run.
According to a new study from University of Michigan researchers Kate Whitefoot and Steven Skerlos, with new CAFE standard it would be more profitable for automakers to keep building larger and larger vehicles:
http://www.washingtonpost.com/blogs/ezra-klein/post/cafe-loophole-could-lead-to-bigger-cars/2011/12/14/gIQA3bGLuO_blog.html
Here is my suggestions on CAFE to eliminate all loopholes:
1) CAFE should be measured in EPA real world test numbers otherwise manufactures would continue to learn tricks to show even higher CAFE numbers which do not translate to real world numbers. 30 years ago CAFE MPG were very close to real world MPG but right now, CAFE 54.5 MPG in real world means only 40 MPG. Otherwise in 2025 CAFE 54.5 MPG could become EPA 35 MPG only.
2) There should be one target for everyone (by 2025 it will be CAFE 54.5 MPG which is equal EPA 40 MPG). Every new car that does not meet the target should pay a penalty of $500 per every MPG under the standard. If one wants to buy a huge 20 MPG gas guzzler he will pay a $10,000 penalty for air pollution and oil dependency. This is the only way to eliminate all loopholes.
3) Introduce gas tax that will gradually grow to $2 per gallon by 2025 to reduce air pollution and oil dependence. Otherwise with high MPG cars will just drive more. With high MPG cars people will still pay less for car ownership than they do today.
So. If you have a vehicle you just want to drive around town, an all electric version is the perfect ticket. Cheap to make, and would cost approximately about 1 cent per mile to operate vs. conventional gasoline at $3.50 and 25 mpg at 14 cents per mile. Vehicle manufacturing cost could fall by $7,500 per unit. Otherwise, if you are bent on a gasoline engine, then hybrids help or better than anything lose pounds. Drop the vehicle weight from 5,000 to 7,500 pounds down to 1,500, and you save all the energy required to accelerate it. Weight equals material and a reduction in material should easily translate into reduced manufacturing cost.
For touring vehicles, surprisingly hybrids won’t help and weight doesn’t matter so much. Instead, you need a low coefficient of drag and a small square frontal surface area. So you are after a vehicle which looks like it was designed in a wind tunnel and sits low to the ground. Remember those high seats, if you lowered the roof of a BMW 5 series by 11 inches, you would save 8 mpg at 70 mph. That costs nothing ! The result is a sports car.
The two biggest problems with fuel efficiency are a) the USA went from the station wagon to SUV’s and F150’s (both heavy boxes with miserable drag coefficients) and b) we dropped from a 1970’s engine compression ratio of 11:1 to the present 6:1. Aside from the need to jettison heavy boxes for vehicles, we need to compress the cylinders with turbo or super charging, and we are seeing the later happen. This would be easier if the fuel companies would start making real gasoline again. When we went from 93-100 to 87 octane, Big Petrol saved 4 cents per gallon and destroyed engine efficiency. The higher the engine compression ratio, the higher the engine efficiency, but it also requires a fuel with a higher combustion pressure. Octane, a substance, not a measurement has a high combustion pressure.
While I have no doubt the industry will take the opportunity to charge for efficiency, it should actually cost less to produce.
Its the driver that makes it better. The engineering boys could make any engine more fuel efficient, long ago. Like Air bags & seat belts..its the driver that makes the difference.
Now, should we continue to strive for practical, common-sense refinements to what we drive? Of course. But let's just back up to these radical numbers (54.5mpg) and re-establish realistic reasons for the degree of improvement in future standards and why/if they are really needed in the first place, other than to just go-along-with big oil haters and other radicals who simply hate the 'status quo' and make us think if we don't do something we will shorten the earth's existence in our lifetime.
In other words, let's never stop striving to improve all aspects of our freedom to drive and our obscession with automobiles, but let's just keep our heads about us and continue on with practical ideas and common-sense projections. We don't want to end our driving freedom and enjoyment of automobiles as the intelligencia, liberal thinkers would like.
Let's just look around at all the radicalism and fanaticism that this current government administration is causing to come out from under all the rocks, and remember,... this too shall pass.
