2013 Hyundai Santa Fe: Uncomfortable Ride With Passengers
Edmunds.com
The complaints started within the first 50 miles of home and I've been hearing them (and echoing them) all the way to Oregon and back. Our 2013 Hyundai Santa Fe has a habit of bobbing on its rear suspension and hammering at our backsides over swales and waves in the highway. It's bottoming out over pavement features it should absorb, and we're not even full.
2013 Hyundai Santa Fe Long-Term Road Test
When we first learned about the new Santa Fe coming in 2 sizes I thought it was a mistake from a marketing standpoint. It looks like it was also a mistake from an engineering standpoint. It will be interesting to see if this is something that's easy to fix or if addressing this will upset the ride in other ways.
I'm having the same issues with my 2013 LWB Sante Fe with tech package. low rear end after a trip. had approx 800lbs in the vehicle (passengers, gear, hitch, hitch carrier and cargo on it), door jam says do not exceed 1111lbs cargo/passengers, i was at 72% of that.
after the trip, the rear end looked low and rear tires looked to have a noticable inward camber. took the car to the dealer for that issue (as well as numerous others, 8 dealer trips on 9 months of ownership) and they are currently replaceing my rear springs. they stated that the rear springs have partially collapsed. they believe this is the reason for the creaking/groaning i hear, rough ride, and low rear end. my bump stops are almost touching the bottom of the spring assembly with nothing in the vehicle.
i'll be curios to see how the car looks once the new springs are in or if the new ones will be any stiffer. Dealer said this is the first time they've ever replaced the rear springs on one, so, we'll see. i'll update once its done.
