2014 Jeep Cherokee First Drive
Edmunds.com
The Cherokee is back. It's still tough enough to climb the trails in Moab, but is the 2014 Jeep Cherokee refined and useful enough to take on the best compact crossover SUVs?
Just foul....
And for the ugliest car, has everyone forgotten about the Mitsubishi Mi-EV?
@ darthbimmer: The Active Drive II 4WD system is effective, but the Cherokee has about an inch less ground clearance than a stock Xterra or FJ. If I was going to hit the trails even once a month, I'd have an Xterra
In addition to the headlight issue, the transmission tends to "stick" or "hang-up" during transitions between gears, especially at speeds under 25 mph. This condition is intermittent and varies in degree of severity but tends to be more pronounced when descending in speed. In the more extreme cases a "clunking" noise/vibration was felt which emanated from the bottom of the car. Jeep updated the transmission software program but this resulted in no noticeable improvement. Note - With Active Drive I, there is no mechanism to manually engage full-time 4 wheel drive. The Selec- Terrain dial which puts the car into Snow, Mud, etc. mode does not put the car into 4-wheel drive - it adjusts other systems. With Active Drive II there is a Rear Axle Lock which is available (i.e., the car is simply an AWD without it). I only mention this because the sales department was apparently trained otherwise; I needed to go to Jeep corporate to get clarification.
One final thought - the customer will do most of the "homework" in trying to resolve these issues. Sales sent me to service, service commented that maybe corporate had a new light design in the works (i.e., the customer should call corporate), corporate asked me if I would ask the service department if they had a different light that could be installed, etc. All good questions that should have been tracked down and answered by someone who took ownership of the issue - FROM JEEP! Meanwhile I have a car the family is hesitant to drive because of headlights that could become significantly impaired.
