2006.5 Kia Optima Road Test
edited September 2014 in Kia
image2006.5 Kia Optima Road Test
Kia's midsize sedan gets a mid-model-year makeover, and the surprisingly good 2006.5 Optima lies in wait for its 2007 competitors.
  • vinwrongengine_vinwrongengine_ Member Posts: 1
    KIA vin indicates timing chain but timing belt installed
    My engine blew up without warning. The Timing Belt broke.
    The problem is that when I bought the vehicle I intentionally went to the Auto Parts store to purchase a timing belt set for my KIA. But the Auto Parts store could not sell me a Timing Belt set because the car had a Timing Chain.
    Later I'm driving along and the engine blows up.
    I rechecked the VIN and it does indicate a Timing Chain. But when the mechanic pulled the engine apart, it had an old broken timing Belt.
    I suggest that ALL auto mechanics everywhere contact their KIA customers to have them bring in their vehicle for a quick check.
    The 8th digit of the VIN number is a 6 for a timing Chain, and the left side of the motor looking in under the hood has a plastic cover that can be opened to see if there is a chain or belt for that engine.
    If the VIN indicates a timing chain, and a belt is installed, then you can get class action suit information at:
    http://kiaenginewrong.pbworks.com
    So based upon all this, I have mixed feelings.
    The car drives great and has otherwise been a good car. But that the VIN prevented me from getting the correct information I needed to do scheduled maintenance is a major issue.
    If you have a KIA, any model, I suggest you or a mechanic visually sighting the timing chain before trusting that the engine has a chain instead of a belt. Don't let your mechanic talk you out of it, I did and now my engine is blown up. Vehicle data is usually reliable, but in this case KIA made a huge mistake by installing a cheaper engine without changing the VIN number accordingly.
    This is easy for a mechanic or even yourself to do in less than 5 minutes. The cover comes loose with a couple of bolts. Don't let anything accidentally slip into the timing belt housing.
