2014 Mazda CX-5 Grand Touring AWD Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
The automatic transmission in the Edmunds.com long-term 2014 Mazda CX-5 shifts smartly, almost as if it's thinking a step ahead of you.
Parroting the same mistake over and over again does a disservice to your readers. It also shows no one at Edmunds bothers to read the comments, which is telling in itself.
Where there's a market there's a way.
and also the fiat 500 when cruising and driving spirited the 6 speed transmission kept the little 1.4 non turbo engine allways on boil. with the exception of on long on ramps where you would have to put it in manual mode to keep it from upshifting. but it would hold gears and bounce off the rev limiter until you requested another gear or switched it back to D. and the gear indicator letting you allways know what gear you are in was a nice touch
