2005 Mercedes-Benz CL65 AMG Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
Checking the oil level and adding oil to a 2005 Mercedes-Benz CL65 AMG.
Digital dipsticks have a frustrating tendency to change their mind in the future. It probably needed oil, but never be totally trusting of the digital gauge because you can't remove the oil without doing an oil change. Be conservative then check the oil level a few more times before you are sure it's still low.
Some of this is meaningless because the crankcase on that V12 can probably handle quite a large variance in oil volume. It's still a good policy.
this is not hard.
with the car warm, turn the car off, wait five minutes, then turn the key to position 2 without engaging the starter.
if you are on a flat surface, you will receive your oil level check.
