2014 Mercedes-Benz CLA250 Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
Most Mercedes, including the 2014 CLA250, come standard with a vinyl upholstery called MBTex. You shouldn't feel cheated, though, as it's better than leather in many ways.
The problem I have with MBTex in particular is that while it may satisfy the eyeball, it doesn't feel that great, although it may beat the stuff BMW uses. And Mercedes is going to use MBTex, then the cars should be priced lower than they are. The A3 has leather, HID headlamps, and a moonroof; the CLA has more horsepower and more gears, and what else to make up for those lacks at the same price.
Personally i'm not all that crazy about leather other than it is easyer to keep clean than cloth and also it smells much better after years/miles piles on. However i am of the enthusiest veriety who apretiates minimalist tech/luxury features and just want to be comfertable while driving with an auxiliary audio input and a good driving car chassis.
The only downside to MB Tex is that most leather packages in the mercedes line up is more than just leather seats. They usually add some sort of door trim stitching or dash stitching. Even the CLA gets door and dash mb tex stitching if you opt for leather. IMO, that changes the whole cabin ambiance. I guess you can't have everything.
There are pros and cons to each type, and on the cars I owned with leather (one new, one quite used), I was lucky that they held up well with proper maintenance, except for the outside shoulder bolster on the driver's seat... makers should always use a heavier grade of leather in that area, function over looks.
That said, everyone I knew with MB-Tex loved it. Eight hard years and 210,000 miles later my V-Tex Jetta looked absolutely like new, no visible wear, and it breathed about as well as leather, just slightly clammier in the hottest weather. People who know materials are fine with MB-Tex in a luxury car, but probably the association they had with lesser vinyl materials in cheap cars results in the irrational insistence on leather. There are some wretched leather interiors I have been in that are worse than even cheap vinyl or inferior cloth.
