2014 Nissan Rogue SL AWD Long-Term Road Test
edited September 2014 in Nissan
image2014 Nissan Rogue SL AWD Long-Term Road Test
Sometimes, the simplest designs are the ones that make the biggest difference, even in a modern crossover vehicle like our Nissan Rogue. Case in point: the storage tray in front of the shifter.
  • legacygtlegacygt Member Posts: 599
    Nothing looks good in an extreme close-up but how's the fit and finish on the interior of the Rogue. I'm seeing some gaps here between pieces of trim including one spot above the far left corner of the tray where I see what looks like an open hole that could be measured with a tape measure as easily as with a micrometer.
  • autojunkie79autojunkie79 Member Posts: 2
    How are the cup holders? I sat in the new Rogue at the stealership while getting my 07 Altima serviced and noticed the cup holders seemed fairly small, recessed and in capable of holder larger water bottles or oddly shaped ones.
