2013 Tesla Model S Long-Term Road Test
Edmunds.com
When we last left our 2013 Tesla Model S, it was on the back of a flat-bed tow truck, here's what went wrong with it.
That being said, it doesn't concern me that much IF Tesla is active in addressing problems and improving Quality Control. Hopefully the Tesla's of 2020 will be near bulletproof.
If not, we're going to have issues when the more affordable versions come out and people start driving these well past warranty periods. Its not going to be acceptable if an Average Joe purchases a 60k used Tesla for $25k with large monthly payments and then has to pay $5k+ for unexpected repairs.
But good points on the early adopters and tech point of view. I'd be livid if my current car was on its 3rd engine but you are right things like that are more acceptable when they are tech. "Just don't hold your phone like that and it will work fine" type of things.
Seriously, why don't they just give you a new car and be done with it? The LCA washers and the rear camber adjust bolts at least make it clear that Tesla is well aware of the tire wear issues (and hopefully, it will no longer be an issue).
Ron, I don't understand how you can an apologist for this company, especially as a consumer advice editor. I especially don't get how you can compare this to the Xbox fiasco when you're talking about a $100K car. Startup "beta" testers or not, nobody should have to go through the experience of 3 engine replacements in such a low number of miles, in a region of the US which is typically very gentle on vehicles. If I were an owner I'd be looking at using lemon laws at this point.
That was an extemely dangerous situation, especially since the flashers died as well. If my wife and child were in this when that happened, I'd looking for heads to roll.
This car reminds me of Second City as it appears to be a not-ready-for-prime-time player.
But of course, this isn't a true long-term test is it? What are the chances that this vehicle, with 3 drivetrains, will be sold to a private party instead of Carmax or Tesla? I say unlikely.
I like our Tesla but these problems are beyond "beta tester" expectations. If we are actually doing the durability testing as well then we should either get an appropriate warranty for the motor (i.e., either match the battery warranty or make it for the entire duration of ownership).
I don't want to have to replace a motor every year for 4 years and find out in the fifth year that it's at my expense...
• The car must still be under warranty
• The owner must have taken the car in for repair of the same problem four or more times through an authorized dealer
• The car must have been inoperable for a total of 30 days (not necessarily consecutive)
You are the consumer advice advocate and yet you do not do the research to find out how much it would cost?
Aren't you just a little bit curious, as a journalist, to find out the facts?
I have to agree with everyone here. This many severe problems so early on is unacceptable. I don't care what "first" of a car it is and most of the people who pay this much for a car are already feel entitled to trouble free ownership.
I'd argue this car has had 1 'engine' swap + 3 transmission and/or differential failures. The battery is the engine. It stores the energy needed to propel the car + provides the HP rating (larger batteries = more HP per Tesla's specs). The drive unit is the trans + diff. Clearly that's still an issue but it sounds slightly better when you look at it this way.
As of now this car has had a near-complete drivetrain swap. I suspect we wont hear about additional drive unit failures unless this is a recurring issue with other Model S owners.
The owner shouldn't really care what it costs the manufacturer to provide warranty service, just whether that service is satisfactory to them or not. That said, the parts removed from this car will likely be refurbished and reused, so the total cost to Tesla is hard to determine.
Such are the perils of early adopters.
Mulsk better get his genie pigs in order!
Obviously a Tesla is infinitely more complex than a computer; but can't it ever be re-booted without calling in flatbeds?
