2013 Tesla Model S Long-Term Road Test
 Edmunds.com
Edmunds.com
Edmunds conducts a Long-Term Test of the 2013 Tesla Model S and reports on how acceleration hurts range.
Have you brave souls at Edmunds tried to determine if the range constantly changes or is even remotely accurate? Just bring a flatbed and a truck with you across the desert. Come on...DO IT!!! The public wants to know! ;-)
According to Top Gear, in their 1 gallon supercar challenge, the Ferrari 599 GTB got 1.7 MPG (UK) around the track. Its tank size is 23.1 imperial gallons, so about 39 miles of range. Flat out, it'll likely be worse, since you won't be braking as you would in a road course.
So lmbvette is right: the reduced range is for 75% a result of recalculating the projected range based on the latest driver behavior, not of real battery depletion, which can't be much higher than a quarter mile per second.
The rated range is about 300Wh/miles.
During the drag (which included speed over 100 mph) :
=> one run ( 0.9 kWh = 900 Wh) is about 3 miles (3x300Wh) of rated range.
=> 3 miles of rated range over 12 s, it's about 0.25 miles per second
The 0.9 kWh include the regen energy acquired during deceleration, so it's about 12 more second.
If you included that deceleration time, you come to 0.125 miles of rated range per second
However, as a side thought, one speaker who had an emergency in their home resulting in the electricity being turned off wondered about being on their own without lights, heat and with no where else to go given her car would be out of "gas"!
