2013 Tesla Model S Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
On Friday afternoon I jumped in our long-term 2013 Tesla Model S and headed home for the weekend. The car was fully charged and its instrument cluster told me it was packing 251 miles of range.
I don't see the need to have to drive efficiently. With a real owner, the car will get charged every night. Edmunds have their charger installed in the office. Scott probably saw no reason to plug the car in his garage. PG&E isn't cheap if you're not on the electric car rate.
many other owners have driven well over 200 miles often, and
with range to spare without doing anything special. The real-world
range is most definitely *not* 120 miles, unless you were driving
100 mph+ the whole time with the heater on full blast. So something
is up here.
I would like an honest assessment of the strengths and weaknesses of the Model S - not a sensational paragraph making brash assumptions based on not plugging in which all EV owners know is a huge advantage. Full disclosure I own a model S with an 85 kw battery pack, it is the best car I have ever driven. Rarely do I ever use more than a quarter of the charge, and the confidence I have starting each day off with a full charge is refreshing. Based on following the directions the range would have reset to full over night, but that does not make a good headline.
Not sure if you're confused by the "rated" range vs. the "projected" range, but your estimate of "true range" is so far off the mark as to be blatantly false or willfully ignorant.
How about you respect the weight that your words have as a journalist and not throw around baseless claims so flippantly? I understand you may have had one experience that didn't make sense to you as a new EV driver, but that doesn't mean you should jump to conclusions. I can guarantee that over repeated drives you will far exceed 200 miles on a charge (even with a heavy foot).
I know 150 isn't great but it's not as sensational as 120. This is sloppy journalism.
The Edmunds crew never minces words, reporting what they did to the car and how the car responded- in the event of "wilful ignorance" the regular commenters typically smack them, but the response level to almost every Model S post is ridiculous. I thought Prius fans were evangelists but this is taking it to another level. If this is what Tesla ownership does to people, forget it, you folks are the worst ambassadors for your brand.
Also: When will we hear from Elon/lawyers?
Is it hard for you to understand that a car that is driven more aggressively will have a range that is much lower. I own a car that claims it can do 350 miles on one tank of gas but if i drive it hard and only in the city then i will be lucky to get 150.
*Assuming 5pm Friday to 9am Monday, and 1mi lost per hour. If Tesla can meet their stated goal with the reintroduction of sleep mode, that loss could be cut to less than 1 mile in the same timeframe.
Vampire load also can account for the discrepancy between "fully charged", and "251 miles". The car was probably plugged in sometime on Thursday and reached a full charge (265mi) some 14 hours before the author picked up the car for the weekend, at which point it showed 251mi remaining.
Get some of those plug receptor thingies and spread em around the walls of your house, they are handy.
