2013 Tesla Model S Long-Term Road Test
Edmunds.com
I recently took our 2013 Tesla Models S Supercharger to see just how quickly it would fill the battery.
Good battery maintenance for lithium ion recommends charging at about 0.3 to 0.5 their capacity per hour, so use of the Supercharger is pushing about 1.0 to 1.5 capacity. The 18650 cells in the Model S are just laptop cells, so Tesla hasn't improved the chemistry at all.
Question: what do you do for an hour while waiting to charge up? Are all these things near shops or something? If you sit inside with the AC on won't it slow down the charge? (Can you even do that while it's plugged in?) Musk said in the battery swap presentation that Supercharging is and always will be free. That sounds too good to be true. But I guess if they put nice coffee bars at all the superchargers they could more than make up for the "free" electricity on overpriced lattes...
Final thought: Those wheels are really badass.
fan-freakin-tastic. u really need to try one if u get the chance.
I can understand spending 20 minutes or so at a station, but an hour is too long. I guess this is where the battery swap station comes int
Tesla warranties their batteries for any reason. So, if the pack goes "bad" from using their super charges, you can just get another one. Tesla has figured out how to fill the batteries quickly because they bypass the onboard chargers a
Not true. The only thing Tesla's batteries have in common with laptop cells is their form factor. The batteries used in the Model S are automotive grade lithium cells with modified chemistry and a different type of anode. They're made by Panasonic to Tesla's specifications.
It seems unlikely that Tesla would allow owners to subject their batteries to life-shortening charging schemes, given that Tesla warrants the battery pack for eight years. The Model S charging cycle is carefully managed by microprocessors inside the battery pack. To protect the batteries, the charging current begins tapering just beyond the 60% level. That's why the most efficient way to charge at the Superchargers is to the 150 mile level. Beyond that, the charge begins slowing down.
