2013 Tesla Model S Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
The cost of electricity varies widely across the USA, and the 2013 Tesla Model S makes more sense on the Oregon coast than I ever imagined.
The original 15 amp outlet in my house melted just from the 12 amp draw from my Volt. It turns out the builder installed the .89 cent Home Depot special. I replaced it with a heavy duty $7 Home Depot special. LOL
For the Volt, if there is any sort of fluctuation in power the EVSE (the 110V external charger) will stop charging the vehicle and blink two red lights. The car will then send me a text and email to let me know that charging stopped or was interrupted. The point of the EVSE is to protect the expensive batteries from any power fluctuations (surge or brown out).
I would imagine that the Tesla charger acts the same way, albeit with much more electricity which can do a lot more damage. I'm surprised they don't require (or include considering the price) an electrician install the charger, considering the amount of power being drawn, 40 amps is a lot of juice.
1) Charge Cord Fault after charging 2-3 hours.
2) No smoke/heat detected anywhere.
3) NEMA 14-50 wiring is long but likely oversized.
4) Tesla UMC tripped but Auto Charge Reduction software did not.
I don't know the UMC design but if it is like most EVSE units, then it is my best guess that Dan's dad's house has a bad wiring on one of the HOT wires for his NEMA 14-50 outlet. The fault isn't serious enough to cause noticeable heat buildup (i.e. burn insulation) but it was enough to trip the UMC's circuit balance detector. The UMC likely wants to see the same voltage and current going through both Hot wires. So if one wire was bad (i.e. more resistive due to corrosion, loose connector etc), then the current flow over time will heat up the weak point, which will in turn increase resistive losses till the voltage drop exceeded the UMC's trip threshold.
