2013 Tesla Model S Long-Term Road Test
Edmunds.com
In Los Angeles, you can never have too much range. When to choose Max Charge in our long-term 2013 Tesla Model S.
Yes, it's called a Hybrid, and until there are many more charging stations, the problem with the Leaf will remain a problem.
I've got two years and 19,000 miles on my 2012 Volt and I charge to 100% every day. Obviously this is easier to do on a smaller battery.
From what I understand, the Volt uses much less (around 10 kwh) of its total capacity (16 - 16.5 kwh) for driving. This buffer, which can't fully charge or discharge the battery, allows the battery to retain maximum use for longer.
I can still eek out 50 miles in EV range if I really want to (not too shabby for a car rated at 35 EV miles). I think GM took the conservative route with the battery design and it will ultimately prove to be a wise choice.
