Slow Transitions - 2014 Jeep Cherokee Limited Long-Term Road Test
Our new long-term 2014 Jeep Cherokee has a nine-speed automatic transmission.
Chrysler has a bit of a reputation when it comes to transmissions. I hope this isn't an indication of things to come for the Cherokee.
If it came with a manual I'd probably have a Trailhawk in my garage right now.
Not sure if it ever went into 9th gear, I heard you have to get to 80mph to reach 9th(?) so it probably did.... It is also really quiet at hwy speeds and has a comfy ride, I actually liked it more than I thought I would. Only thing I didn't like was the surprisingly aggressive throttle tip in. Really have to feather the gas for an easy take-off.
The transmission is assembled by Jeep, but it was designed and engineered by ZF, with Jeep tweaking it for Cherokee duty. Acura also uses a 9-speed ZF transmission on some of their vehicles, most likely a variation of this unit.
