Easy-to-Use Navigation System - 2014 Kia Cadenza Limited Long-Term Road Test
The Kia's navigation system, which is standard equipment on our top of the line Cadenza Limited, is perfect.
The screen on my mom's 2013 Tiguan is easy to reach, but it's small and isn't angled towards the driver at all. It also has no sort of glare protection, so it can be hard to read in direct sunlight. That's one of the big benefits of iDrive or Audi's MMI; most of the models integrate the screen into a part of the dash that provides some glare protection while also keeping the screen higher up and more in line with the view of the road. Acura/Honda has a decent idea with using a touch screen to control a larger primary display, but so far, its implementation has been somewhat awkward. I normally prefer knob-based controls like MMI or iDrive unless a touch screen is exceptionally good. It's still more comfortable (and safer) to use controls down by the shifter (where you normally rest your arm while driving) instead of having to glance down at a screen to figure out where to touch. The less time your eyes spend away from the road, the better.
Even though this was just released, most of the exit numbers that I was given around Louisville, St. Louis, and Nashville didn't match the signs. True, most of the roads in all three of these cities seem to be under construction, but they weren't even close.
I was told to keep right onto I-40. But going right would have taken me onto I-26/I-240. And though the arrows on that screen correctly pointed me to the left towards Knoxville, the other signs for Asheville and Johnson City were shown blank.
I took a side trip to Springfield to see the Capitol, but on the way back, the system showed the signs wrong and I took the wrong exit. I realized I wasn't headed towards downtown St. Louis and I finally just pulled off because it was obvious I was going to be well to Kansas City before the system ever recalculated. In fact, it never did; I ended up canceling the route and resetting it using the Previous Destinations function.
I was told to keep right onto Tenn. 6, which was actually signed as US 31E! The drawing of the road wasn't clear that how I should go.
It wanted me to detour off US 25 SB to avoid a traffic jam that wasn't there and I seriously doubt ever existed just outside downtown Travelers Rest, SC.
And a few times, after the system default timed-out on the shortest time function, guidance never actually started until I hit Menu and pressed Start Guidance even though I'd already said that to the voice command system.
Lastly when I got home I found that it wanted me to turn left onto a different street to get to my house, which would require driving by my house. I tried to use the error reporting system on the MnSOFT website, but it's absolutely useless to even try to do so.
I don't think Edmunds has much time left with the Cadenza, but considering it's a press fleet car, I think it'd be worth asking Kia for the drive and doing the update to see what the results are. Mine aren't good.
