Rough Rider - 2014 Mercedes-Benz CLA250 Long-Term Road Test
The 2014 Mercedes-Benz CLA250 is a good fit for the narrow confines of the big city, but its ride around town leaves much to be desired.
I suggest you go out and buy a Mazda 6 and check their suspension tuning out and maybe reverse engineer it. Maybe even take a Caddy CTS V-Sport for a ride and look at how it can really be done. Luxury car ride for everyday but select track mode and you can pull .90gs on the skidpad. One word...Magneride.
I think a bigger problem that applies to many other cars besides this is that more and more makes are giving their models larger wheels with lower profile tires. This is fine on performance-tuned models, but anything below an aspect ratio of 50 or 55 doesn't provide enough of a buffer between road imperfections and the suspension IMO. Couple this with the fact that a lot of cars are equipped with performance tires instead of touring/grand touring tires and you end up with cars that are almost inherently set up to ride harshly. In extreme cases, the lower profile tires can even lead to problems with blowouts, bent rims, etc. if the driver isn't careful enough to avoid potholes and other obstacles.
What manufacturers need to do is either group things like sportier tires, suspension tuning, etc. into packages or at least allow buyers to select different tire/wheel combinations. My mother's 2013 Tiguan SEL has 19" rims with 40 series tires which can make the ride a little harsh. Lesser-equipped models have smaller wheels with thicker sidewalls, but in order to get all of the equipment she wanted, she had to move up to an SEL and take the larger wheel/tire combo as part of the package. Manufacturers need to stop lumping things like this together, or at the very least, provide another option for buyers that don't want or need aggressive wheel and tire packages.
Also, I agree with @chol92594 that automakers have gone a bit too far with low profile tires. My 135 has 19s, and I feel like those are overkill on a car its size. I'd rather not go bigger than 18", and I'd probably be fine with 17s. My e36 M3 had 17s and handled great.
