Isuzu Trooper Won't start!
jmoo39jmoo39 Member Posts: 2
edited December 2014 in Isuzu
I have a 97 trooper that I started up then adjusted blower speed it just died! And wont start back up! I just replaced battery and starter two weeks ago. Any ideas what could be the problem?
  • thecardoc3thecardoc3 Member Posts: 5,870
    Is this now a cranks but won't start or no-start won't crank?
    From there what is missing, spark? Fuel? (pressure and injection pulse) Can you test compression?
  • jmoo39jmoo39 Member Posts: 2
    It cranks but does not turn over. Tried starting fluid not even a slight change. Fuel pump is turning on. Its just not getting spark. any suggestions?
