Installing a TeraFlex HD Hinged Tire Carrier - 2012 Jeep Wrangler Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
The oversized tire and wheel package was too heavy for my 2012 Jeep Wrangler's tailgate, so I installed the TeraFlex HD Hinged Carrier.
How about paint integrity where the old hinges came off and the new ones go on? Am I seeing nothing but primer under those hinges? Good for you that you're in the SW...no wonder Wranglers up here in the NE are such rustbuckets.
Larger tires like mine aren't just heavier, they also have a center of mass that's even farther away from the tailgate because the wheels and tires are wider and have a different backspacing. It's the wrenching torque of that bouncing mass that does it, so the tailgate's troubles are compounded because that extra weight is sitting farther out at the end of a longer lever arm. The bolts on the body side don't care so much about this, though.
Twitter: @Edmunds_Test
One thing about having a CJ-5 as your first car, like I had back in '74, is that I avoided shopping the old style CR-Vs and 4Runners in later years. Those gates are a pain in the assembly, if you get my drift.
That said, big (and heavy) tires and wheels are a popular non off-road and extra-profit DEALER upgrade. The factory tailgate and spare tire carrier design should probably better-account for this reality. But they'd still have to draw the line somewhere even if they did beef it up. Where would they stop? 33" tires? 35"? 37"? The weight and wheel width can get silly in a big hurry.
@stever: Thanks.
