2015 Hyundai Sonata Long-Term Road Test - Introduction
Edmunds.com
Will the 2015 Hyundai Sonata continue its predecessor's success as the midsize sedan's styling matures?
Well... you're being a little naive about the drivetrain. It's fairly good, but it's far from bullet proof.
The 2.4 Theta engine is mostly good, but they're not exactly a long-term warrior. I've read plenty of forum posts (at least 5-6) of this engine dying well before 100k. The big problems are, 1) if you're the original owner, you better have every documented oil change record, or Hyundai will deny claims; 2) The 10/100 only applies to the original owner (which your girlfriend is), so a few of those people were stuck holding the bag for a new engine at just past the 60k miles mark. One was completely SOL around 35,000 miles, since he/she couldn't provide proof the car was maintained by the previous owner.
As for the transmissions, they're average... my '12 SE 2.4 was starting to slip in cold temperatures. Dealer said it was old learned driving habits. They reset the TCM and called it a day. Problem persisted. Going by others with the same issue on the forums, it required a transmission replacement. My car had 35,000 miles on it when it started doing it. I wasn't alone with this issue.
Since I was the 2nd owner, I was afraid of long-term reliability, and the fact that I was only covered to 60,000 miles. I traded it in for a new '14 Elantra GT, which is also starting to have some minor issues at 14,000 miles and only 5 months old. 1) rough idle, 2) high beam switch issues, 3) thermostat is going bad already, and some other minor stuff. This will be my last Hyundai/Kia. I'll be cutting my huge losses, and unloading this car. It'll be cheaper for me to put money into keeping my '05 Passat 1.8T 4Motion on the road, versus the payment and trips to the dealer in my future with this Hyundai.
If she has any trouble with the stereo, they're only covered for 3 years, 36,000 miles. If it happens just outside the warranty, just install aftermarket. The dealer wants outrageous prices for those crappy things, and they're known to be unreliable. Another common problem area is the starter: they use cheap plastic for a part that should be metal.
Oh, make sure she contacts the dealer for pending recalls. Hyundai/Kia are horrible at contacting owners, and I know there are at least a couple for the '11 Sonata.
Your or she should really sign up on hyundai-forums dot com. It's an excellent site.
