Engine Additives
245
  • nstinenstine Member Posts: 2
    now snake oil is a different story....
    It's enviromentally correct (assuming you are not the snake that did the donating), a renewable resource, biodegradable, available in all 50 states and I have yet to see any owner's manual advising against its use. It is in limited supply in the winter which is why I switch to 5W30
  • goteygotey Member Posts: 6
    Big Al said his Jeep was running at 200F, Unless my shadetree mechanics fails me, most thermostats open at 190F, at least in american iron, which the car senses as normal operating temp. i absolutely agree that running a engine too cold will cause sludge, etc, unless you change to a colder thermostat (160F for example), it shouldnt be a problem.....and no , I dont work for prolong either, and i dont use it...but if it works, more power to ya!
  • avs007avs007 Member Posts: 100
    I wasn't referring to his situation. I was just clarifying when someone said that running cooler isn't always better... I should have stated I was talking about people who swap out their 195 degree thermos for like 165 or 175 thermos, to reduce running temperature....
  • kevm14kevm14 Member Posts: 423
    Our 96 Maxima SE 5-speed has a tad over 60k miles and is actually 1,500 miles overdue for an oil change - it is scheduled (as well as the 60k service at a private shop) for next wednesday. My dad does not feel that Mobil 1 is worth the cost, but I think it is...so I just wanted to gather opinions on whether I should foot the bill for a few quarts of Mobil 1? It's not my car, but I drive it a lot, and given the fact that it's a 5-speed, I tend to rev it up more than once in a while. so will the car last longer? Run cooler? More power? Go longer between oil changes? What, if anything, can I expect? Also, longevity is priority number 1 in my family, and if Mobil 1 increases this substantially over a standard conventional oil, I want to know!!
  • hohohoho Member Posts: 64
    I believe that if you change your oil on a regular basis and you use your car the way it was designed to perform you dont need all the market hype of late. Someone a whole lot smarter than me (and most of us for that matter) designed the engine to run utilizing a certain type of oil. Stick with it. As a retired person who now works at an oil refinery ican tell you this... dont use wax based oil. Despite the operating temps it will gum up faster and cause you more in repair later.
    As for changing thermostats.... the same applies. If you do decide to mess with your thermostat start a auto parts store so you will have the needed parts later on.
  • bluemistbluemist Member Posts: 23
    Although I don't have the oil refinery experience, I thought that synthetic oils (such as Mobil 1) were based on natural gas, not wax.
    I've found that synthetic oils provide superior protection against wear, but this is NOT something you will notice unless you drive the car for 200,000 miles, which very few people do.
    My parents will keep the car until it doesn't run anymore, unless they give it to me after college (in which case I'd want the engine to be in good shape anyway).
    I did not mean to confuse anyone. Mobil 1 is not a paraffin (wax) based oil. Some lower quality oils are made from this type of distillation process. Mobil 1 is not one of them. I like to use Quaker State (gtx = multigrade) oil for my cars. Texaco (havoline 3) is another, and I am not promoting either of these. They just work great for me. Besides, it is good for me to get under there to see if there are any other things I need to see, like cracked CV boots, leaks and what not. I hate surprises when it comes to spending money foolishly.
    I have found that almost all oils though, subject to time and exposure to heat and friction will degrade to the base elements (thick goo = sludge). Mobil 1 or any type of synthetic oil does not justify the price when you follow the time proven schedule of vehicle maintenance.
    I do agree with and wont contest that synthetic oils are blended for harsher service and do hold up to extreme heat and friction alot better than conventional oils. If severe service is the main reason (and not laziness), then by all means use it. and maintain your changes on time. Still, to me, the cost doesn't justify the gain unless you just don't care about your vehicle.
    If you want, this site has some interesting information on oil filters for all that oil.
    Again, sorry for the confusion. Rick
    http://minimopar.simplenet.com/oilfilterstudy.html
  • orange606orange606 Member Posts: 32
    I have a 90 accord with 118,000 miles on it. We have run mobil 1 for most of its life. The other day i had to replace the oil pan gasket. There was absolutely no slug, or debrie of any type in the oil pan. I was wondering if any body who has had to do similar service on a car with similar mileage with regular oil, and what they saw. I am not saying that i wouldn't have seen the same thing if i had used regular oil. i am just
    curious. We also plan on driving this car until the engine falls out of it.
    I replaced the front trany and rear engine seal on my 88' Ford taurus s/w. It had a little more miles than that, only 10k more. I replaced the timing chain and gears as well as all gaskets (oil pan, vlv covers, front seals and such). When the oil pan was taken off there wasn't any sludge at all but the pan and the inside of the valve covers were stained brown a little. I used Castrol GTX 10-30 and Havalin 3 for the whole time. I changed the oil & filter every 3000 miles. All the other filters and fluids get changed every year just before winter sets in. I don't beluieve the repair reciepts add up to over 2000 bucks yet and We have 157K miles on it.
    Ah, that wasn't the Mobil 1, that was the Deadline you must have used as an additive! :)
  • no2retailno2retail Member Posts: 1
    I have tried many of the engine treatments. I did
    not notice any difference in performance. I do
    use either a full synthetic or synthetic blend (my
    favorite-Castrol syntec.) I bought a used '87 VW
    Vanagon that was serviced from new with Mobil 1
    5w-50 oil. It now has 143,000 miles on the original engine, the compression is within factory specs, does not burn oil, and runs strong. I think by using a high-quality oil, mineral or synthetic, regular oil changes, it is
    not difficult to achieve long engine life. There
    is no need for additives/treatments.
  • lxpatellxpatel Member Posts: 34
    i have been informed by an owner of an old 82 Lincoln Town Car owner that if your engine is not getting performance like when it was new, just add a bottle of ISOPROPYL ALCOHOL AKA RUBBING ALCOHOL to your full tank of gas and you will see the power restored and take all the carbon out like all these fuel injector cleaners. i have tried it and it seems to make the engine alittle better. does this have any merit?
    i have been informed by an owner of 82 lincoln town car that every six months it is wise to add a quart of transmission oil to your engine to remove sludge and keep it in top notch condition. Is this okay, cause i have all cars from 94 onwards i dont have throw off any sensors and have it stop working completly.
    another trick to remove sldge was, according to him, was to add disel to engine oil after draing the old oil completly and flush it out and replacing with new fresh oil. i was informed by a mechanic few years by a mechanic of this being true only if done correctly by him, of course. BUT I DONT GO THAT MECHANIC SINCE I NOTICED I ENDED UP GOING TO HIM EVERY FEW WEEKS TO GET SOMETING REPAIRED. since i have been going to dealers and being taken for a succor, i have not been there for any other major repair execpt scheduled maintainance.
  • clintonjohnclintonjohn Member Posts: 99
    I think diesel oil in the crankcase would be similar to stories of adding kerosene, which from what I've gathered, isn't too different from stuff like 'Marvels Mystery Oil. Yeah, it'll probably dissolve some sludge, but my worry is that some of the residual kerosene/diesel will stay in the engine and dilute the fresh oil change.
    As far as isopropyl alcohol, it probably works much like 'Dry Gas' It binds any water in the fuel line and gets it burned off. Don't know about removing gunk from fuel injectors. Don't most gasolines(at least here around Chicago) already have 10% alcohol in them already? Don't see what a 16oz bottle added will do.
  • blugillblugill Member Posts: 36
    If your going to add it, add somehting like ISO-HEAT. (one brand) The drug store stuff may contain unknown aditives that are not good for your engine, the ISO-HEAT has additives that are designed for your car. Alcohol is a good cleaner, and if used regularly will keep your engine clean(er), but if used rarely will clean it all at once, dumping the sludge where you don't want it.
    Remember, you can buy alcohol from most gas pumps nowadays, and it essentially does the same job. Brand name (and most off brand) gas contains cleaners too.
  • markbuckmarkbuck Member Posts: 1,021
    Most alcohol in gas is ethanol (grain alcohol).
    Most dry gas is 100% iso-propyl alcohol (IPA).
    Most rubbing alcohol is 70%IPA/30% water. Buy the 100% IPA if you are gonna stick it in your car. The OTC drygas products are probably cheaper than 100% IPA from the drugstore.
  • spokanespokane Member Posts: 514
    Markbuck makes a good point; you want the 100% iso-propyl alcohol. By combining with any residual water in the gasoline, you also have protection against fuel-line freezing. With today's fuels, however, I don't know that alcohol addition offers any benefit.
    As to ATF or diesel fuel to the crankcase, please don't do it. Diesel fuel is not a lubricant and you are almost certain to incur some bearing damage immediately. Many people did advocate this procedure several years ago ... but it wasn't a good idea then either. See info in the engine oil topic.
  • user12345user12345 Member Posts: 2
    Awhile ago I had a stalling problem with my 92 Passat. I finally solved it by using brake part cleaner to clean the idle stablilzer valve. Before that though, I tried several fuel additives to see if they helped. The very best was Techron. After five minutes I could tell the difference. It didn't solve my stalling problem, but it is a very good product for keeping those injectors clean. I still use it today, about once a year. There are two types of Techron. The Proguard is cheaper, seems to be a diluted version of regular Techron.
  • gusgus Member Posts: 254
    Techron is the only additive approved by Volvo for use in its vehicles--or so I've heard.
  • sbspencesbspence Member Posts: 16
    I just purchased an '88 T-bird Turbo Coupe with 47k one-owner miles. The owner used pennz 10-40 only, and changed oil every 2k mi. I have been told differing stories on synthetic oil. One person told me to use nothing but synthetic for my Turbo application(in fact Mobil-1 was supposedly recommended by Ford for this car new)
    another person told me that if you change to synthetic after using regular oil for so long the engine will develop oil leaks. In fact some people have said not to even dare change the brand as this will lead to leaks or sludge formation aaaargh! What is the REAL poop?? thanx
    Far as I know, not car requires synthetic. It is better oil though, just that it isn't so much better that they require it.
    Synthetic oil will not cause oil leaks, sludge, or the like. However, if your engine has a leak, synthetic is small enough/slippery enough to find leaks that regular oil will not find. It won't damage the seals, but if the seals are border line, synthetic will show the problems where you might go for years with regular oil.
    Synthetic likewise won't cause sludge, but the additives might be better detergents, and therefore clean all the deposits, which were harmless in big passages, but will clog the small ones, (hopefully just the oil filter) as it passes through.
    Personally I'd go with synthetic on newer cars if I can afford it. If the car has problems or is old don't bother. For Turbo cars, synthetics can take more abuse then normal oil, so it is a better idea yet.
  • guitarzanguitarzan Member Posts: 879
    A car that old might have seal problems with synthetic. I would ask the dealer.
    I think it is a tough call. How much of the life of the turbo is gone? Maybe an inspection could tell. The guy did GREAT by keeping the oil clean. Hopefully, he also idled a bit to let the turbo cool before shutting the car off, and didn't stomp on the gas upon starting the car. I think these habits might make that baby last longer than any oil type change.
    The C5 Vette as well as the Porche come factory filled with Mobil 1 Synthetic... GM even states that Mobil-1 Synthetic is the only approved oil for the LS-1 engine in the C5....
    Yes, but don't dare put synthetic in older Porsche's. The ring clearance is too large, and the oil seeps past it.
  • geo4w1geo4w1 Member Posts: 1
    You fellows remember the infomercial by Prolong where they treat various engines with Prolong, then drain the oil out and seemingly drive the cars, including a Viper, for hours w/o any oil and supposedly cause no damage, not even overheating? Well, a while back Consumer Reports had two identical engines rebuilt to specs, added Prolong to one, drove both cars a little more than a hundred miles and then drained the oil from both. After 8 minutes and 5 miles of driving, both engines seized up at about the same time -fried!
  • ccotenjccotenj Member Posts: 610
    those ads are amusing, although i'd never seen one where they drive the car... usually it's just the engine, and one would think that the reason that they run "for hours" under that so-called simulation, is that the engine is under ZERO load... i'd be willing to bet that you could take any engine straight from the factory and run it for a LONG time under those conditions.
    thus when CR did their trial... BOOM....
    my 2 cents... or prolly a cent and a half....
  • slwinderslwinder Member Posts: 8
    I own a 1986 Honda Accord LXI with 206,000 miles. I have regularly changed the oil every 3,000 to 3,750 miles using a high quality regular motor oil - Penzoil 10/30. The engine runs great and has never burned oil. I have never had to add oil between oil changes. I'm convinced that regular oil changes is the key. I would only consider Synthetic oil if I owned a very high performance car such as a Vet or any car with a Turbo engine.
  • penberthypenberthy Member Posts: 1
    The oil plug "fell out" of my 86 honda accord (treated with slick 50), and I drove home with the "no oil" light on...since then I have utilized an oil additive in all my vehicles
    Lets see now...Your "no oil" light came on and you STILL drove your car home?
    Don't even know what to say.
  • davidb9davidb9 Member Posts: 3
    Someone wrote something about six months ago--but it doesn't matter when it was written if it's complete bushwa--about paraffin-based oils: '...As
    and cause you more in repair later.'
    I'm still low on the learning curve about such matters, but I'm pretty sure that's an urban myth. Here's what the Pennzoil web site says:
    "Few, if any, misconceptions about motor oils have been so widely circulated as this one: 'motor oils containing paraffin can leave deposits in engines.' No one seems to know how this misconception got started, but it sometimes appears to have taken on a life of its own.
    Most major motor oils today are formulated using paraffin-based crude oil. And they do not leave behind deposits in engines. In fact, one of the reasons paraffin-based oils are used is to insure against deposits. The confusion apparently begins with the fact that our first introduction in life to paraffin is as a wax.
    When motor oil chemists speak of paraffin they are referring to relatively non-reactive hydrocarbons, extracted from crude oil, which have excellent oxidation stability. That stability prevents oils from breaking down under extreme operating temperatures and as a result are unlikely to form deposits.
    Motor oils not formulated from paraffin-based oils use naphthenic-based crude oils and are more likely to leave deposits in engines."
  • jcwidmanjcwidman Member Posts: 7
    RE: mjr #28
    I know this response may be posted after the issue has lost it's interest, but I am new to the forum and was reading old messages. Interesting!
    mjr asked about moly (#28, May). It is molybdenum disulfide MoS2. It is sold by several vendors; the stuff I had was made by Acheson. Moly is a solid so it comes as a fine powder suspended in an oil base.
    I worked at a small research company in Michigan for 12 years, and the scientists there would buy a 55 gal. drum of it then everyone would take a quart or a gallon for several years' use. It is an excellent wear inhibitor and prevents (OK, *almost* prevents for the purists) metal-to-metal contact. You use just a couple of ounces in your engine oil.
    I was skeptical and called a Ford lubrication engineer for his opinion. It was: Yes, if the particle size is small enough it will do as claimed. It is very slippery, adheres tenaceously to metal and it is almost impossible to force it off (hence prevents parts wear even at high pressures). MoS2 particles must be less than 1 micron. (Acheson was 0.1 micron as I remember). I asked if it is so good why isn't its use more widespread? He said Ford tested it, and found it to be a good additive. But it is very black, stains easily and permanently, and is messy and just disagreeable to work with. Oil technology is sufficiently advanced these days that it really isn't needed. You can't tell your oil condition by looking as it is opaque and very black.
    I put it in our family cars regularly for awhile, now once in awhile (not close to every oil change).
    I don't know if it has helped or not. We've had no lubrication related problems on our cars (last car 177,000, wife's and my present cars 124,000 each).
    Changing the oil regularly probably is sufficient.
    #89 Davidb9
    David,
    I, too, was confused by recommendations to avoid paraffin-based oils. My old chemistry text says that there is a 'paraffin' series of compounds starting with methane (a gas, 1 carbon) ethane (2 carbons) which are 'saturated' i.e. no double bonds, and so on. If you go higher in the seies you get octane (the fuel, 8 carbons), then oils, then waxes. The word Paraffin means little affinity, or little reactivity.
    The point is, just because it is paraffin-based doesn't mean it has waxes in it.
    It was my understanding that most oils deriving from mineral oil ('DD' here in this forum) are paraffin based.
    Perhaps those Forum authors recommending against paraffin-based oils would be kind enough to provide more details on which oils are paraffin based, which are not, and why.
  • mwiklemwikle Member Posts: 62
    Broadly speaking, Motor oils are made from 3 types of base oils:
    1) Paraffinic solvent-extracted base oil(this is "standard old technology"). Solvent extraction pulls out the wax, yes wax, from an oily distallate, often called "VGO" "vaccum gas oil". They are slightly colored without additives, because solvent extraction does not remove all impurities. The wax is used to make other products like firelogs, etc... Called "group 1" stocks to insiders.
    2) Hydrocracked & catalytically dewaxed base oils. This is a chemical reaction made to the oil stream to eliminate wax. These oils have many "semi-synthetic" properties. Chevron has the leading technology here, it is used by many refiners. Some oil co's are trademarking these "water white" base oils which have very low impurities. These oils called "group 2" in the industry. The industry is generally moving toward these types of oils to meet the new GF-3 specs due in 2001.
    3) Synthetics are made from the ground-up as an oil molecule (methinks starting with an organic gas stream). Typically PAO's [polyalfaolefins] and some others. Syns are benificial in some applications, most folks do not need them and will get full engine life without them.
    ALL motor oils may be thought of as "parrafinic" in nature --- this is GOOD!!!
    Napathenics base oils are the other choice, these oxidize easily and are a niche product today.
    No end-user of car motor oil needs to be too concerned about this stuff as long as a major brand oil meeting spec. is used.
    In the late sixties, I worked in a Mobil station where we did quite a bit of mechanical work.
    We had an excellent mechanic at the time named Bob, who hated Pennzoil and Quaker State oil.
    When he would pull a valve cover off a sludge filled engine, he would say " Here's another Pennzoil engine!" After asking the owner or by looking at the door sticker, he was usually right!
    His favorite at the time was Havoline made by Texaco.
    So, to this day, I won't use the stuff! Maybe things are different today?
    Quaker state has kept that reputation up until very recently. Rumors are hard to decipher, but everyone I know who is involved with cars still repeats what you have said.
    As for Pennzoil, perhaps the racing money has helped development. I used 5w030 Pennzoil for 5 years in my Integra, with fine results.
    guitarzan
    Community Leader/Vans Conference
  • usmcpaousmcpao Member Posts: 5
    O.K., I bought a '88 Honda Accord, 135K miles. It's running fine but would like some assurance. Do I bother adding Dura-Lube/Slick 50? Or perhaps just get a good tune-up?
  • hall2hall2 Member Posts: 40
    I had '86 Plymouth Conquest. I put Slick 50 every 50k miles since 43K miles I had in the car. I changed oil approx. 3k miles; never let pass 5k miles. At 176K miles, never have to add oil/no burned-up. For all those miles I put in, I had two bad injectors, a leaking manifold gasket, a blown radiator hose(frozen), 1 thermostate, 2 replacements of cheap tires, went into the ditch 4 times and bent struts(rear wheel drive in MN), and got stuck in the sand at Orlando beach, FL. At the end, 186K, the turbo charger went out. I traded it in. I got $200.00 for it.
    The point is I think the Slick50 worked for me. I use it in my '94 Nissan Maxima. It currently have 96k miles.
  • arjay1arjay1 Member Posts: 172
    The Slick 50 did not prevent your turbo from burning up in only 186k miles!
    Do you not think your Maxima would have made it to 96k without the Slick 50?
    It sounds like you do good, regular maintenance. Don't waste your money on additives.
    None of these have proven to make any difference. I bet your Conquest would have crapped the turbo with or without Slick 50.
  • rlkb99rlkb99 Member Posts: 1
    In case U didn't know, The FTC has sued the makers of Slick 50 for misleading customer by putting false claims on the performance and capabilities of Slick 50. I am using TufOil myself and I found it to be much better.
    O.K., thanks for the responses re: Slick 50, but what about DuraLube?
    Just use a quality oil and change it often.
    will say it again... if ANY of these additives worked as well as they claim, all oil manufacturers would put them in their addpack and advertise the heck out of it... that they don't should probably tell you something...
    do a search on slick 50 on the web... read some of the research that's been done... buyer beware.....
    I've got a great .html page I saved on oil additives. It is no longer on the web, but if you email me, I'll send it to you. Basically it reiterates the above: Do not use them. They do not work, and they only open up the possibility of damage.
    guitarzan
  • frozentundra1frozentundra1 Member Posts: 10
    Jason-
    I've added Duralube to BOTH my turbodiesel and normally aspirated gasoline engines. They run great. However, since I've added it, I've done a lot of snooping at Consumer Union, the web, and an old petro-chemical engineer buddy. They all say what Craig "Isellhondas" said: Don't waste your time or money. Change your oil <5000 miles regularly and you'll get optimal engine life. Reason: Today's "SJ" oils are VASTLY superior to the SE/SF crap we all used in the 70s. The quality of the oil, and the longevity of the additives in today's "SJ" oils mean you don't have to use Duralube. If I had it to do over again, I wouldn't waste my money.
    Anectodal evidence: I doctored up (with sexy additives my supremo deluxo 76 280Z with 297,000 miles on it when we had twins, and had to buy the Volvo. On the other hand, my wife's Datsun 510 (same engine, but only 4 cylinders) just got treated with regular Quaker State oil every 5000 miles (despite that bad juju some have said about QS oil). The non-treated engine looked MUCH better (less deposits, less polishing of the camshaft) than the one I did all the special treatments too. I'm still trying to figure that one out.
    -psycho
    p.s. Happy birthday, Marine.
  • b3u12b3u12 Member Posts: 7
    Can some explain to me what is the real diffence between say 10W 30 and 20W50.why did they come out with a heavier oil and what would be the advantage of one over the other?
    tHANKS
  • pat455pat455 Member Posts: 603
    There is another topic in this conference on engine oil, #19 - Engine Oil - A slippery subject. Why don't you peruse it to see if your question has already been discussed? If not, you may want to re-post it there.
    Pat
  • lucky20lucky20 Member Posts: 35
    A laymans discussion of oil viscosity. Multi grade
    oil is designed to give a rated viscosity index at operating temp. (aprox. 250 deg. F) equal to the larger of the two numbers, & a cold oil index equal to the lower of the two. Primary importance is the operating temp. index.
    30w oil, at operating temp., will maintain aprox. .001 in. clearance between two conforming surfaces. If a eng. crank-shaft main & rod bearing clearance is set at .001 in. (common in the automotive industry) 30w oil will provide good lubrication. At the same time, if we try to use 50w oil for the same eng. we are sure to suffer bearing damage and failure due to the fact that 50w oil, at operating temp. will not be able to get between bearing & crankshaft surfaces.
    The best policy is to always follow manufactures recommended lubrication oil for all components, (eng., trans., PS. etc.).
