I can't make a connection to the computer through the access port under the steering column.
I determined that the port lacks current. I have checked all the fuses that I can find. I found one fuse panel under the hood on the driver's side and one in the kick panel on the driver's side floorboard. The check engine light is on and I was told that is what is causing it. Has anyone else had a similar problem?
Best Answer
thecardoc3
Member Posts: 5,858
Power should be on pin 16. There should be grounds on pins 4 and 5. Most code pullers require the vehicle power and grounds to turn on, but a self powered scan tool only needs the ground connections and the data lines to communicate. if you tell us what year and model your Mazda is, then we can tell you exactly which fuse supplies power to the data link connector.5
Answers
Ric
What is the symptom you are dealing with that you need communication? Depending on whether the car runs or not, and what works or doesn't work it's possible to figure out if the car should have communication or not.
BTW does the scan tool turn on? You have the power and the ground connections if it does. The fact that the doors lock and unlock proves that at least some of the car does have a good data network. The keyless entry module is on the high speed bus with the Instrument Cluster, PCM, TCM, EPS, and more.
Have you tried a different scan tool?
Under a full throttle acceleration (you need to have a snapshot of this to replay from both an accuracy as well as a safety perspective) how high does the engine load data pid go?
