Low Tire Pressure - 2014 Mini Cooper Hardtop Long-Term Road Test
Edmunds.com
Our long-term 2014 Mini Cooper warned us to check the tire pressure, but which tire?
As far as nitrogen goes, ambient air is already about 78% nitrogen, so filling up your tires with pure nitrogen will provide little benefit, if any. Plus, it's pretty much impossible to fill a tire with pure nitrogen, since air will be trapped inside the tire when it's mounted to the rim. You would have to continually fill and release the nitrogen, which would get pretty expensive.
Also, regardless of the tire type (run-flat, conventional, summer vs. all-season, etc.) you can't really tell if a tire is low by just looking at it. This has been proven extensively. If a tire DOES actually look low, it's probably well under the recommended PSI and warning threshold for the TPMS system.
How many times are car owners told that the TPMS is a safety net - that it's NOT a substitute for regular manual checks of tire pressures (and "regular" is taken to mean like once a month, not once a year), including on Edmunds' own site?
Donna, this happens time after time with Edmunds LT cars. Who there is supposed to be doing stuff like this?
This morning I woke up out of town to temps just under 20°F and the light was on, so off to the closest tire shop I go. One tire was down to ~34, rest were the "normal" 38 psi. Aired up the tire and took off but the light didn't go off. Stopped 5 miles up the road and rechecked the psi and it was holding air okay. So we continued on a 40 mile backroad through the Gila NF here in NM to the cliff dwellings. After the fourth stop (aka "driving cycle") over the next hour, the light finally went off and I was able to quit worrying about it.
Without information like this and tools like this company provides shops wouldn't be able to keep up with all of the different systems. One reason that a lot of cars have to be driven has to do with how fast the sensors go to sleep and quit broadcasting the tire pressure. When driving the sensors react top the movement of the tire and broadcast all of the time. When stopped they go to sleep in order to try and increase battery life.
