Checking the Oil - 2015 Jaguar F-Type R Coupe Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
Santa Claus has given me what I wanted for the holidays: our 2015 Jaguar F-Type R Coupe. (Or, more accurately, our vehicle manager Mike Schmidt said it would be okay to take the F-Type for Edmunds' holiday break. Still, lucky me!) But I figured it'd be a good idea to check the car's oil since I'd be away from the office for a while.
Why is stuff like this considered a convenience?
It's the fact that if the car has just been driven, all of the oil is still up inside the oil galleries - it has not drained down into the crankcase again, so if you check it too soon after running the engine, you'll get a false low reading. That's why checking oil when you buy gas is a BAD idea. With a dipstick, you get around this by checking oil after it has been sitting for say 10 minutes minimum...but you could also do it after it's been sitting overnight, or for a week or a month.
But if you have this stupid system that wants the oil hot to do its measuring, then you have to have it hot, but not so recently run that oil is still draining back down. So you have to hit this dumb sweet spot time-wise. Ridiculous.
The regimen has always been that you check tires and fluids first thing before driving the car...oil is all down in the crankcase. All fluid reservoirs are marked with a hot and cold fill level except the brake master cylinder, which doesn't really get hot at the reservoir. Also you could check your tires then, because tire pressure is checked cold. You could do it all at once, in other words. Now with systems like this one, you can check all those other things with the car cold...and then you have to come back and make a separate effort to check the oil.
why are they mutually exclusive???????
Isn't it his job to check this stuff? Oil, coolant, tyre pressures etc ? Or is he just the holder of keys?/
I've even come across one of the editors holding up traffic on Venice Blvd in the Fiat 500 long term car a few years ago as she was talking on her cell phone!
I have used this site to buy my Mazda via the contact the dealer directly link. Which was a great experience, and interestingly the price I paid was much less than Edmnds' TMV...
Shout out to Galpin Mazda!
