2014 Nissan Altima Whistling Noise
I just got a Nissan Altima 2014 on Friday and noticed today that theres some type of whistling or whirling noise it makes with the heat and fans off when you drive slowly and stop. Does anyone know if the whistling or whirling type noise is normal?
My 2014 Altima SV has a noisy A/C Blower fan when set in the last 3 highest settings. I took it to the dealer and the mechanic took out the blower and clean it out. He said he found debrie that would cause the noise. It was working for one day and the next day the noise started again.
A/C Fan on High settings is noisy. Maybe the A/C Fans are low quality and they are noisy in many of them? I will take it back again and discuss it with the service advisor. Lucky for me it is a Lease. I would be very unhappy to have bought something that cannot be fixed.
I suspect that it's the wind passing through the cabin, over the passenger side rearview window or something else that the wind passes over.
It' annoying but can't find the cause since it happens generally when the window is down while the car is moving.
