Side mirrors get a reflection from air vents! Has anyone else noticed this on there TLX?
tim251tim251 Member Posts: 1
edited January 2015 in Acura
    Do you mean you're seeing a reflection of the air vents in the mirrors, or are you seeing the air vents reflected on the windows as you look at the mirrors? If the sun is shining on the air vent on the driver's side of the dash nearest the door on my car, there are times I notice them reflected on the window as I look at the side mirror.
    With that silver trim around the vent, and the geometry of the situation, I'd bet this is what you're describing
    Have you tried adjusting your mirrors the SAE way? That may help with the reflections.
    How To: Adjust Your Mirrors to Avoid Blind Spots (Car and Driver)
