Cruise Control Brake Overuse - 2015 Kia K900 Long-Term Road Test
Edmunds.com
Our 2015 Kia K900 regulates speed closely when descending grades on cruise control, but ours seems to rely too heavily on the brakes to do so.
This strikes me as a calibration/strategy issue that could be fairly easily remedied by their engineers.
I'd also be interested to see if there are any lasting consequences to the brakes from the run. Perhaps check the discs for runout? It would make for a cool Edmunds Garage piece, something that's been sorely lacking as of late.
Also, maybe I've just never driven down a steep enough grade, but I don't think I've ever witnessed a cruise control system shutting off as a reminder to the driver to take control.
In the K900 owners' manual: Advanced Smart Cruise Control system (ASCC)
Do not use the ASCC when it may not be safe to keep the car at a constant speed, for instance, driving in heavy or varying traffic, or on slippery (rainy, icy or snow-covered) or winding roads or over 6% uphill or down-hill roads.
I am certain that you could actually over-ride the transmission manually with the cruise engaged so as not to rely solely on the brakes under those steeper grade situations. Also, 6th gear would likely hold the speed with almost no other intervention needed.
But the issue was not as acute back then because the automatics only had three or four gears. They couldn't accommodate insane overdrive ratios like this 8-speed. And when a cruise control system a) has adaptive capability meant to control speed and maintain safe following distances as traffic gaps grow and shrink and b) seems to have downhill speed logic because it regulates speed so effectively, the implication is this is a smarter cruise control that can handle downgrades. From where I sit this one is not smart enough.
Twitter: @Edmunds_Test
http://www.k900kia.com/advanced_smart_cruise_control_system-368.html
Dan,
You used the ASCC in a manner the owner's manual explicitly states not to use. It is only fair you update the post to include the driver's error omission from your earlier post.
Besides, the system wasn't in adaptive cruise control mode. I dropped it into normal cruise mode (easy to do) because I don't like the way this car's ASCC system behaves.
And this issue of grade steepness is no excuse for the system choosing to ride the brakes instead of downshifting. Maybe I should try this on Baker Grade, a 22-mile 4% downgrade on the way back from Las Vegas--in summer.
Jay Kavanagh (our resident engine development engineer) and I used this fact (along with other tips) to beat others in the Audi Mileage Marathon mpg competition in a diesel Q7 some years back. Others coasted down long grades in neutral, but we always coasted in drive. The former requires fuel to keep the engine turning, the latter does not.
