Speed sensors on the transmission - Diamante
burch57burch57 Member Posts: 1
edited January 2015 in Mitsubishi
which sensor shift the gears on the transmission?
  • thecardoc3thecardoc3 Member Posts: 5,860
    They all work together in concert to input data to the transmission computer and it decides which solenoids to command On/Off to select the different gears. Exactly what kind of a problem are you having? Has anyone pulled trouble codes from the PCM and TCM?
