Fuel Economy Update for January - 2015 Ford F-150 Long-Term Road Test
Edmunds.com
Fuel economy update for our long-term 2014 Ford F-150 for January 2015
I'm sure the 2.7 will beat my 5.4 in a drag race, but this is a dang truck. I use it for hauling and for going places that involve off road elements (hunting).
I don't tow. I don't drag race. All that aluminum and turbo tech in the motor says one thing to me: Higher cost. Oh, and it says another thing: Higher cost for no benefit.
It is not right to assume that the consumer expects that cars will miss the EPA number because this is a matter of degrees. If you look at a company like Mazda that is trying to come by its fuel efficiency honestly, they have cars that might have lower EPA numbers than a Ford but end up being more efficient in the real world.
@sxty8stang I wouldn't be surprised if the 3.5 ecoboost actually is more efficient. Under similar loads it would need to spin the turbo less than the 2.7 and might be more efficient and more pleasant to drive. I'd love to see Edmunds get a hold of the same F-150 but with the bigger ecoboost engine (and how about the two naturally aspirated engines as well) and see how they do head to head under the same conditions. (I actually had hoped they would have done the same thing when they had the Explorer and see if it did any better in the real world than a FWD explorer with the naturally aspirated V6.)
The issue of turbo'd engines not living up to their EPA figures is real, but overblown. Heavy footed drivers will fail to see EPA estimates no matter if they are driving an ecoboost or a pushrod OHV V8.
Twitter: @Edmunds_Test
There is much more to it than just this, getting the fuel economy up and meeting emissions requirements makes for a very complicated problem for the manufacturers.
Does anybody do that anymore?
I used to with my Powerstroke but i got addicted to that torque and gave it up.
It was good for 3mpg in town when i did.
If my old man was alive he get 18 in town with that Ecoboost and he wouldn't get in anyones way.
He would just be and always was very judicious and precise with the gas pedal.
And CHEAP.
To quote Garret trubochargers...
"There are actually three ways to reduce the probability of knock at full load on a turbocharged engine: reduce boost, adjust the AFR to richer mixture, and retard ignition timing. These three parameters need to be optimized together to yield the highest reliable power."
So if you heat up the intake air charge on an engine that was used to manufacture EPA estimates by reducing the cooling capacity of the intercooler by shielding approximately 25% of the cooler to prevent condensate from accumulating then it reasons to logic that the charge air is hotter. Which raises cylinder temperature...so then whatcha gonna do?
To reiterate Garret turbochargers...
I don't know about your truck but I'm running 14.3 mpg combined. To be fair I live in somewhat hilly terrain but on the level at 60 mph I am running 14-15 mph on the present scale fuel consumption...I think someone owes me for a lotta fuel since I bought this to save on fuel...I like the section of the Garret quote personally that states..."adjust the AFR (Air Fuel Ratio if you don't know) to richer mixture"...as it would seem to go along with the poor mpg I experience.
Am I the only one to have noticed that a 2015 that weighs 700 pounds less has a poorer EPA fuel estimate for a comparably equipped 2013 because all of a sudden they have figured out a better way to rate vehicles in fuel economy? So they have wanted to tell us the truth but couldn't figure out how to sell us trucks in the interim but now that they are able to improve fuel economy they lower EPA fuel ratings while having made the truck more fuel efficient? That is really out there as a concept.
Actually I think that is where we were deliberately misled...but you love the torque so you are all seemingly quite forgiving...the new lower EPA rating on a lighter truck really got to me personally because it is a blatant manipulation. I wonder if certain Ram vehicles hadn't come along that can actually make its numbers where we would be?
Swamp
This is better than my old Explorer 4.6 4WD with 3.73's got under the same circumstances, except I ran that with RUG.
We also have a couple of vehicles with 2.0 EB engines. I like them.
My wife drives a titanium AWD Escape, which averages 1.3 below the EPA 24 combined, but 1+ better than the 3.0 Escape it replaced.
After 3 years, my Fusion is averaging just under 28 MPG, rated at a combined 26.
