Nevada Road Trip, Part 2 - 2014 Jeep Cherokee Limited Long-Term Road Test
Road tripping in the Edmunds long-term 2014 Jeep Cherokee Limited.
Agree completely re: the excellent Adaptive Cruise. I have been using it for almost all driving as it smoothly brings the car down to a full stop and then just a tiny tap on the gas and it resumes and smoothly takes you back to speed. A vast improvement on the Laser Cruise on our 2006 Toyota Sienna that resumed using full throttle.
A new feature on the 2015 is the auto stop/start. Supposedly saves gas; will have to see if it is worth the annoyance factor. Interestingly, it doesn't seem to activate when the car comes to a stop via the Adaptive Cruise. First time the engine shut off I thought it had stalled.
The downside of this strategy didn't occur to me until I drove into a light snowstorm. The sensor on the nose of the car began to ice over until the adaptive cruise dropped out and displayed an error message. I wanted to solider on with traditional cruise, but I was unable to engage it. Traditional cruise control did not need the now-blocked sensor, but the activation strategy described above meant it could only be reached by first engaging adaptive cruise -- which was unavailable because of the ice accumulation and the error message.
http://www.edmunds.com/lexus/gs-350/2013/long-term-road-test/2013-lexus-gs-350-van-horn-texas-to-home.html
The separate buttons on the Cherokee avoid this problem. Kudos, I say.
Twitter: @Edmunds_Test
Now, nobody will believe me when I say this, but my GLI (6MT) has THE BEST cruise I've ever seen on any vehicle. Up-hill or down, I never see ANY speed fluctuation. I guess this is the result of a manual XMSN and turbo 4. Now, that's what I like about Cruise Control: It maintains a set speed. All I need to do is pass when I come up close to someone, then get back over and my speed never strays. Isn't that what Cruise is for? Am I missing something? I have a feeling this is like Start-Stop technology in that I'd disable them if I could, or not purchase the thing if I can't.
Some cruise controls allow you to go faster as you go downhill, such as on my '99 Grand Cherokee and '06 Chrysler 300C AWD. Every system has its own way. The Cherokee will slow you down to keep the set speed. This is both good and bad, depending on your preference. Of course, you can always just hit "Cancel" or slide the shifter to "Neutral" if you want to allow it to roll more freely.
On the Stop-Start, so far I've generally liked it. As soon as you take your foot off the brake it restarts. If you are aggressive it might not be quite fast enough for you, but you can always come off the brake a bit early to restart it in anticipation, especially if you've got enough space to roll slightly. Thus far the only place I've found it to be annoying is when I pull in the garage. If I don't put the shifter in "Park" quickly enough, it shut off the engine as if I'm at a stop light. Then when I do shift into "Park" it restarts the engine just when I'm done. I haven't read the manual yet, so I don't know if there are preferences that can be selected on how this feature works.
#1 People behind me think I'm driving like a [non-permissible content removed] because my breaklights are constantly being activated. Where a person would just take their foot off the gas, the adaptive cruise systems don't seem to handle coasting well. It's either throttle or breaks.
#2 If I pick the closest setting in my Infiniti, it acts a little erratic, If I choose the longest setting it works better but then people will pull in front of you and at that point the cruise control freaks out.
What I've found is that it works fine on two lane rural roads but not so great on multi lane interstates. At that point I just turn off adaptive and use regular.
