Whats wrong with my lights, fuse, wires?
2000 Avalon . Now when I use the key fob to lock/unlock, the outside lights do not flash. Also the park lights aren't on .
Best Answers
thecardoc3
Member Posts: 5,862
How much it might cost is the lesser of the problems that you are facing. Finding a shop and tech familiar with and skilled in the routine is the biggest problem for you right now. A shop that can do this effectively will give you an upfront estimate on the order of one to two hours of diagnostic time. The most that they can promise is to not go over the two hour limit without talking to you so that you have an idea of what is going on. There are many occasions that the one hour minimum is plenty of time hence the range to start out. As you try to find a shop to look into this, something to keep in mind is a shop that excels in this kind of work will have a separate labor rate for diagnostics then they do for regular repairs. The regular labor rate is calculated to also have parts being sold which is a portion of the gross profits, when doing diagnostics there are no parts being sold and therefore to be successful the shop must account for that.2 -
thecardoc3
Member Posts: 5,862
You need to find another mechanic who tests with the kinds of routines that I explained.5
Answers
so removing each bulb one at a time and/or swapping it with new bulb may provide a good clue to the root cause, retesting with each individual change. (sounds like you probably already have a huge pack of new fuses on-hand...)
BTW. There are several exposed sections of the circuit inside the truck that can be easily accessed and unplugged in order to try and narrow down which branch of the circuit that the failure is in. Without the right tools and a solid routine you are limited to the labor intensive routine of simply disassembling random sections until you manually discover the problem. Pinched wires behind any of the lamps are a possible cause, even a defective bulb can do this. We have also found abraded wiring harnesses where the trunk hinges are.
So I guess I will start with changing bulbs
