Mazda B-Series Starting problems
I have a Mazda B4000 and I am having problems with it starting. About two weeks ago it would not crank, then after a couple of days it cranked again. It has been doing fine for the last week. Now I am driving it more to anf from the work site and today it will not crank again.
I did have it checked out and the mechanic said he didn''t find anything wrong with it. He did say that it needed new plugs and wires because the originals are on there.
What on earth could be a cause of this?
It won't crank, then it does and drives for a while, then it won't crank again.
Any help or advice?
Any help or advice?
kcram - Pickups Host
Used a wire brush,(Much like a bad battery connection) reconnected it and Bahhhm!
Very unusual! very economical to fix as well!
I should have use a volt meter to check that line. I Must get in the habit of that.
Hope it helps someone with mysterious and intermittant starting issues.
has spark and fuel.any suggestions?
The new starter has only 3 bolt holes.
I have the same situation
My truck has been starting OK during the daytime
In the evening - I need to crank it several times - before it will turn over
We have a 94 Mazda B4000 that has this intermittent starting problem. The dealer charged us $700 to look for the cause, and told us there is nothing wrong. Avoid dealerships at all cost. We started knocking the fuse box with our knuckles while the other person turned the ignition and it started. Discovered that it is a square relay within the fusebox named the EEC, basically Electric Relay. Others have noted that the power to radio and lights also was interrupted when it did not start. Replace the EEC relay.
https://youtu.be/CbGM4HoIyhU
